Is my wash mitt leaving micro-scratches?
lj993
I have a couple of microfiber wash mitts. As I recall they are the Supreme Micro-Chinelle model. I wash them between car washings. I have noticed that after even one light wash, I am getting micro-scratches on my paint finish. (the wash mitts that I am using are about a year old) Are these wash mitts a help or a hindrance? Do the mitts collect dirt and grit and in turn leave micro-scratches on the finish. I had just detailed out the one of our trucks, Blackfire One Step, the week before the wash. The truck wasn't particularly dirty, just normal dust. I also noticed the same type of micro-scratches in one of our other trucks too. Straight front to back lines, just like I wash the trucks. I am thinking that it might be better to just use a micro-fiber towel rather that using the wash mitt. I usually start on the hood, which is where I noticed the micro-scratches. Since I start on the hood, that is the area where the wash mitt would be the least likely to be embedded with dirt and grit. I usually squeeze out the dirty wash water before I put the wash mitt in the rinse bucket. After the rinse bucket, I get it lathered up with soapy water. Maybe I need to go to the multi-mitt wash method. Thoughts? Phil
i've never been a fan of those chenille noodle style wash mitts and can't say that's the source of your problem, but you may want to try another wash mitt and see if that reduces the scratches/marring. take a look at your microfiber and drying towels and add a drying aid such as a qd/spray wax (if you aren't already) to avoid dry buffing/friction as well...
It could be the mitts aren't cleaned out properly or you just have sensitive paint finish. Try spraying the area with a water/soap mixture right before you wash it.
This is why I only use sheepskin mitts and lots of them
Great... now that I ordered the set of them......
try this method and if see if it helps out. if it doesn't, just dump the rest of the solution from the bottle into the bucket next time you wash...
Ha ha, Al I remember that wash when they sold it here, I used it for years.
if you think about what the guy is saying in the video it makes sense. as you wash in a bucket it gets diluted down as you bring the mitt back into the wash bucket from the water pooling on the panel (from rinsing as well). this is why i like using a foam gun to wash because i get the same consistent amount of soap solution as i spray/wipe/wash the panel...
This ^^
and tons of lubrication too :)
So that dude is saying that instead of just putting multiple mitts in a wash bucket [we’ll go with 12 mitts since he did say up the 12] and tossing them into an empty bucket, which leaves you with a 0% chance of watering down your wash solution...
He’d rather walk around the vehicle with his mitt, having to waste his time and energy repeatedly dunking it into a bucket full of water and a grit guard after each little section, and then have to pick up a spray bottle and pull the trigger a bunch of times onto the face of that same wash mitt...
Yea, as if starting the wash having to spray wheel & tire cleaner from a spray bottle wasn’t enough of a PITA. I sometimes start my wash process going around to each wheel, back to back with 3 spray bottles [1 for wheels, 1 for tires, 1 for the wheel wells] and it’s impossible to spray all 4 corners with just 1 hand. [meaning all that spraying gets your hand tired as heck] And this dude thinks it’s a better idea to keep on with this process of unnecessary spraying from a bottle? That’s ridiculous.
Not only that, but he’s taking that Meguiars Soap Gel and instead of using it @ the recommended 1:128 ratio, he dilutes it into his spray bottle @ 1:9 [or 9:1 if you prefer to look at it this way]
Then he takes it even further with his dilution of Meguiars Ultimate Wash & Wax. Recommend dilution of 1:128, he dilutes it @ 1:7 [or 7:1]
Do I want to wash my car with a car wash dilution of 1:7 instead of the normL 1:128? Hell no I don’t... That would be the equivalent of pouring 48oz. of Megs Ultimate Wash & Wax car soap for normL 3 gallon bucket wash.
And all this extra work and higher concentration for what? Am I supposed to believe spraying soap solution into my mitt from a spray bottle is going to yield more lubrication than pulling a mitt from this bucket?
IMO that’s the dumbest detailing video I’ve seen in a while. He must’ve been out of ideas when he came up with that 1.
This.
Most likely just something trapped in the fingers that isn't washing out. Time to buy a new one. OR you've changed shampoos recently (and /or dilution ratios) and have been getting less lubrication in each wash.
I can't recall how long I've owned my CG MF chenille mitt and it's served me quite well.
You might be running to hard to and or not getting enough loose dirt off before using mitt. I do a foam personal and rinse before using mitt. I still get them though. I think it's impossible not to but some paints won't show it.
I agree way over complicated
I'd be looking at the drying end of the process. at least that's where I seem to get all mine from. I always wet my vehicle down before washing. even when I do a rinse-less wash I carry a spray bottle with a detail mixture & spray the panel first. I've got a black truck with soft clear coat & I'm never going be swirl free. so I'm not always trying to get out every single swirl or scratch.
hmardown
hmardown
I was just thinking the same thing, could be from drying.
I'm a curious person so I tested this method. Used carpro reset and was suprised that I didn't get the same lubrication as when 2bm washing. Think that the mitt holds up alot of water that diluted the spray schampo way more than a bucket does for me. So no this method was not something I will be doing. And that is what it is with youtubers. Some are great that they comes up with and some not. He does how ever have some other big and intresting thoughts and ways with detailing. But you can not blindly think that every thing is what suits you. And so is it on the forums also I think. A simple solution to fatigued from spray bottles is pressure spray bottles. And if you are useing more than 32oz there is those that holds over a gallon too. IMO it's easier to pump up pressure than pump spray triggers. I have seen Griots Garage has released pressure spray bottle and a foam pressure spray bottle. From the looks of them it seems to be from a company named Mesto that does high quality pressure spray bottles. That some holds higher than Kwazars. Just a tips from me :)
I think that a really thick MF mitt is actually a bad thing. The dirty stuff does not release easily. MF is supposed to hold onto things.
I prefer sheep skin wool mitts or wash pads. They are super silky when wet and for me they release the dirt better MF or sponges.
This thread reminds me to order more Sheepskin mitts. Unfortunately the days of getting them locally are just about over. I had a whole bin full of them marked individually by section and I would go around and wash that section of the car and grab another mitt marked for the next section and move on
I use waffle weave drying towels for the drying process and never to waterless washes. I just ordered a few more micro-fiber mitts on the 25% off sale. These micro-scratches are a pain. I have a foam gun, but haven't been using it as much due to California's latest drought worries. I may try it and see if the added foam suds make a difference. Thank you all for the thoughts and ideas. Bottomline, wash mitts can leave scratches, drying towels can leave scratches. I may have to wax it every week.......Phil
Other solution, pick up some ONR and drop an ounce into your wash bucket with soap. It'll help with dirt release, and use a drying aid or something like that. I use waffle weaves as well, and I don't scratch until I try to start a fire with the waffle weave and the clearcoat. Maybe instead of wiping back and forth as well, try blotting out the water, that might work better as well. Or since you're in California, switch to rinseless washes. Use the MF mitts and a bucket of a rinseless wash, have a mixture of towels and the mitts, and don't reuse any. Wash one panel, dry, next panel next mitt/towel.
