is there a point to cleaning tires?
op1001
I was just curious, what you guys think about this?
I see a lot of people spending money on products to clean tires etc, but in reality they only clean the side where the they will apply trim to..
Sure we can spray tire cleaner onto the tire, but reality is most of us are probably just scrubbing the visible area to clean and protect
SO really what good does it do to the rest of the tire?
Nothing really no?
Short answer, so tire dressings bond better:xyxthumbs:
so reality is we are only dressing one side of the tire , which really means the rest of the tire is still unprotected .
I still treat the inner side every tire rotation to prevent cracking
I don't worry that much about the inner side of the tire since the sun doesn't hit it all day long. I clean my tires thoroughly every wash so my tire dressing bonds to it properly.
I clean them because I like them clean. I don't put any dressing on mine. I just like them nice and black without dirt or dust. I suppose I could put some spray wax on them for UV protection. I've never had a sidewall crack before I wore out the tire.
I think a clean tire is important on a dark colored vehicle. All the time detailing the paint is for naught if all you can see is brown or gray tires. Clean tires is even more important on trucks and SUV's with bigger tires. A bigger sidewall is more noticeable than a low profile model.
Something my dad said to me when I was a kid and complained about making the bed when it is going to get undone every night when I goto bed.
He then said to me why bother eating? You're going to get hungry again!
Sorry, I know the OP's question is legitimate but I thought I would add some humor this morning.
Well I guess we can polish the heck out of our paint to get it looking perfect and just leave the tires dirty, somethings wrong with that picture. Naw I`m going to clean my tires and put everything on them to make them look great, by the way if you do this your wheels will look better also. Oh I forgot to mention polish the heck out of your wheels also. Doing these things will keep the world in balance and it won`t give you any time to sit around and pick your nose.Im the MAN
Besides 'aesthetics'...
I believe there actually is a point, or more, to be made about cleaning tires.
As such:
-I look at it as part of a preventative maintenance program for not only the tires themselves,
but also for the wheels (inner and outer barrels), braking-system components, and the wheel-wells.
-How am I to conduct a proper inspection (include safety-check) of these vehicle areas
when they are dirty, full of brake dust and other corrosive elements?!?!
I do realize that:
-The removal of the tire/wheel assemblies is not always feasible.
-But as it has been mentioned:
The inner-sides of these assemblies are not subjected to as much (if any)
of the destructive UV rays as the outer sides.
-When I pull these "assemblies" is when they receive more intensive attention.
Besides the possible savings in the long run...
My life, and the lives of others, depends on where the rubber meets the road...IMHO.
In closing I can only suggest:
Make sure you clean your tires (and surrounding components/parts) thoroughly, and often.
i do an off vehicle wheel and tire cleaning regiment every 5000 miles when i rotate the tires, as well as a brake inspection and cleaning. i also pull, inspect, and regrease the caliper slide pins.
Inside of tires? Lololol, not cleaning them other than that pressure washer.
Sent from my DROID RAZR MAXX HD
I clean my wheels and scrub the tires every week when I wash my car. I then apply Mothers Protectant to the outside of the tire and spray Protectant on an old microfiber and wipe the other side of the tire the best I can. The only thing I have never done is take some Protecant and a micro with me when I had new tires put on to wipe down the inside. Obviously I have thought about but was afraid I would be too OCD. I also was afraid the tire dealer would think I was nuts or object. But I still think it could be a good idea! ??
I'm genuinely impressed.
What do you use to grease it with? I hope it's silicone paste.
You have to be careful what you use on brake pins. Some of the silicone brake grease can get very sticky and make your pads hang up.
I've found that Lithium soap base glycol grease works well. It's probably best to use dealer recommended lubricants on your vehicle. I went for years working as a mechanic using what we had in the shop that day that seemed to be the best fit but in this day and age everything has it's own special lubricant for a reason.
The inner sides of the tires are also not subjected to the wide variety of soaps and cleaners used on the outside of the tires. Not sure how big a factor that would be but just adding it to the conversation.
The biggest enemy to tires is non-use. That's why tires on vehicles not used every day appear to rot more than tires on daily drivers. For example, tires on an RV that is used for summer vacations but sits idle the rest of the year.
I've been told that the way tire manufacturers create tire rubber formula is to include an ingredient called "antiozonant" that works its way outward via inertia as tires rotating at highways speeds. The antiozonant keeps the sidewalls flexible so the won't crack. When the antiozonant meets ozone in the air it turns brown, this is called blooming and it's the brown residue you often see on the sidewalls.
Someone emailed this to me a few years ago. He didn't give the author credit so I don't know who wrote this but it certainly isn't mine to claim. It talks about "blooming" that you mentioned above.
Tire Detailing
Tires are critical to the overall appearance of a car and yet are often overlooked. Considering the fact that tires are in continual contact with the road and suffer from adverse effects of road tar, dirt, grime, water, salt, brake dust, grease AND ultra violet radiation (UVR), ozone, and oxygen, it is understandable that they require great care. Over time, tire rubber simply degrades. As a matter of fact, vehicle manufacturers recommend, independent of tire mileage, that tires be replaced, typically after six years, as a means of preventing sudden failure!
From a detailer’s perspective, not only do we want tires to look nice (i.e. appear new), but we also want to protect them from the elements identified above. A properly cared for tire will add significantly to the overall appearance of a well-detailed vehicle. With this in mind, let’s first try to understand one of the most obvious negative visual features of a tire: tire browning.
Tire Browning: Blooming
Modern rubber formulas used by tire manufactures contain an ingredient called Antiozonant. An antiozonant is a chemical that tire manufacturers add to the tire rubber to help prevent rubber degradation (cracking, splitting, oxidizing, and overall deterioration) due to the rubber’s interaction with ozone (an odorless gas that is part of the air we breathe). Quite interesting is the fact that tire rubber is designed to constantly work the antiozonant to the outside of the tire as it rolls – in this way, the outside surface of the tire is continually replenished with fresh antiozonant. This process provides the positive result of ozone protection, but the negative result of tire browning – once the antiozonant gets exposed to the ozone in the air, it turns brown due to oxidation. The technical term for this effect is blooming. The next time you are in a parking lot, observe the tires on the vehicles you pass – most likely you will see a brownish film on the surface of the tires. As we will discuss in a moment, you can wash your tires with car wash soap or an all-purpose cleaner (APC), e.g. Purple Power Cleaner Degreaser, to remove some of the film, but it will simply return in a few weeks! Every time you drive your car, the antiozonant migrates its way to the outside of the tires. One thing you might be aware of is the fact that vehicles that sit for extended periods of time (months or years) often have tires that show evidence of cracking and drying (dry rot). This cracking occurs due to the fact that there is no opportunity for the tires’ antiozonant to migrate to the surface to provide protection.
Tire Cleaners
So, how can you successfully clean and protect a tires surface? As mentioned above, using car wash soap or an APC will enable you to remove some of the brown film from tires and this, in most cases, is all you will need. A word of caution. A trip to your local auto parts store will yield a number of products designed to clean tires. Some of these products contain harsh cleaners and detergents – using a harsh tire cleaner may also remove the outer layer of tire rubber and may have the detrimental effect of increasing tire blooming as more antiozonant will migrate and permeate the tire surface during flexing. As with every aspect of a car, use the least aggressive method first! This simply means to use the least aggressive cleaner and least aggressive cleaning method – if this does not work, move on to the next aggressive product and/or method.
As a first step, you will need to gently clean the tire surface. The tire cleaner you use needs to be strong enough to remove existing contaminants but not so strong that it damages the tire or wheel coating. I typically clean my tires using the same soap as I would use to wash my car (Meguiar’s NXT, Meguiar’s Gold Class, Optimum No Rinse, Pinnacle Body Work Shampoo, P21S Total Auto Wash, etc.) along with a soft bristle brush or wash mitt (the type of wash mitt is not crucial). As long as you use a reputable car wash soap, you should not have problems. Keep in mind that completely removing the ‘browning’ may not be possible – that is OK. Once you apply a tire protectant (dressing), the browning will disappear.
Tire Dressings
Prior to the application of a tire dressing, you need to make sure the tire is cleaned as per above to properly prepare your tire for application of a protectant or dressing (and that the tire is dry). Keep in mind that tire dressings won’t adhere to or create the right shine on a dirty rubber surface. As is the case for tire cleaning products found on the market, there are also a plethora of tire dressings.
There are two types of tire dressings you will find on the market: water-based and solvent based. Water-based dressings, often a milky-white liquid, should not harm rubber over time. Water-based dressings are typically a combination of naturally occurring oils and synthetic polymers that provide a very nice non-greasy, satin-like finish – very similar to the look of a new tire. Some water-based tire dressings also contain UVR blocking agents to help keep tires from cracking, fading and hardening. As an added bonus, most, if not all, water-based dressings are friendly to the environment. I have had excellent success with Meguiar’s Hyperdressing, an extremely nice all-around rubber dressing that doesn’t ‘sling’ off tires as you drive. Stoner More Shine and Meguiar’s Hot Shine are also nice tire dressings but tend to leave the surface of the tire too shiny. Perhaps the best product I have used is 303 Aerospace Protectant…spray on the tire, leave for 5 minutes, and then wipe off the residue. Solvent-based silicone dressings, often a clear, greasy, sticky liquid, leave a wet, glossy film on the tire surface. Be careful, some solvent-based dressings contain petroleum distillate solvents that, over time, may lead to premature drying and cracking of the tire surface. The difference between water- and solvent-based dressings is simply in the ‘carrier’ system used. Solvent-based products use a hydrocarbon silicone to suspend the product whereas water-based products use water. When you apply these products, the carrier evaporates leaving behind the intended protectant – silicone oil; this oil is not friendly to the environment and may harm the tire. In addition, solvent-based silicone dressings have the tendency to sling off the tire onto the paint.
While application of a tire dressing is quite easy, there are a few points to keep in mind. First, don’t apply too much dressing. Simply apply some dressing to a dedicated tire rag, towel, or foam applicator and wipe the dressing on the tire to provide a nice, even coverage. Be careful not to get the dressing on the car or the wheel – particulary when using an aerosol spray. Stoner More Shine and Meguiar’s Hot Shine both come in aerosol cans. Meguiar’s Hyperdressing typically comes in a gallon size container. Hyperdressing needs to be diluted as it is very concentrated. I dilute it 1:1 and have had excellent results. Some other detailer’s dilute it 2:1 (2 parts water, 1 part Hyperdressing). Either way, you will need to find what is best for you and what look you are trying to achieve. A gallon of Hyperdressing will last a long time and is very cost effective. Third, a few minutes after you apply the dressing, wipe the tire with a clean rag or towel to remove any residue. And fourth, try to keep the tire dressing off of the tire tread. Tire dressing, either water- or solvent-based, will make the tire tread slippery.
While all of the above may sound a bit complicated, the procedure is actually quite simple and will only take a few minutes per tire. In the end you will end up with a well protected tire that looks like it came out of a show room!
