Don M
Active member
- Jan 8, 2010
- 2,254
- 14
I have been using UQD as a drying aid with great results. After a few suggestions that I try UQW instead, I gave it a try. I was surprised to find that instead of working as well or better than the UQD, the Quik Wax made the paint splotchy and left ghost images of the water droplets that had been on the paint, mainly on the horizontal surfaces (which BTW were losing their beading rather quickly) I finished drying the car with UQD and tried to use the UQW again with fresh towels, but at least on the horizontal surfaces it left smearing, water spot 'ghosts' and cloudiness
. I'm ready to put a coat of ULW on to see if that removes the smearing etc, if need be I'll use a polishing pad to apply the ULW. The finish is still flawless and swirl free, so I know I don't need to polish the paint, I just need to figure out a way to rid myself of the smearing and ghosting.
It was in the later afternoon with full cloud cover, not too hot and I would guess low to medium humidity. The towels I use are very absorbent and I only use 1 because after I wipe the towel across the paint, what little bit of water left behind evaporates too fast for me to get a second towel and I don't want to dry wipe the finish. Reapplying UQW didn't do any good, it just deepened the smears and water droplet ghosts and I didn't have any luck using UQD to remove the ghosting/smearing wither, I just switched to it on the remainder of the car after I saw what was happening and when I couldn't "fix" the problem. I even tried wiping with more pressure than I was comfortable with and a dry towel and all that did was fade the ghosting a bit, but I could feel how slick it was from the UQW. I even tried using a damp (water) mf immediately followed by a dry mf to see if that would level off the finish, but nope, still blotchy
Part of me is saying to do a 2-step on the car-polish to remove the spotting and rewaxing to seal the paint again, but other than the issues with UQW, the car looks awesome, no scratches or swirls, no paint fade (remember it is SS paint) and no staining from contaminates. As of now it's been a little over 12 hours since I touched the car, so I'm going to go outside to see if time has made any difference. I might even try reapplying some UQW or UQD (if the blotchiness is still there) to see if a second LIGHTER application makes a difference. Update to follow ...
*****Basically I went outside and it had sprinkled. There was a drop or two of water every square foot or so and a few light streaks. I used a clean cloth and buffed the streaks along with any nearby water drops and the streaks buffed out. Looks like there must have been too much water in the equation last night, because it seems like the 12 hour 'cure time' cleared up the topical issues. I don't know that I'll be using the UQW for drying anymore, it doesn't seem to like water (DUH, it's advertised as being highly hydrophobic). So I guess I'll continue to use the UQD for drying and apply the UQW for protection. I think I might have been the problem, using too much UQW ... I think I'm going to start holding the sprayer a lot farther away from the car and only using an ultra-fine mist instead of a heavy spritz, it seems like that should work better.
Any other suggestions would be appreciated
