Hi Mike, thank you for your answer.
I think this might happened due to sun damage, no sanding was done to the car.
I understand and didn't mean to confuse you or anyone.
I added the point about wetsanding BECAUE it's often a topic of interest and no matter how many times I try to explain it to future detailing expert, it never seems to sink in.
Paint is thin
If you sand it - you increase the already present risk for CLEARCOAT FAILURE. It happens on it's own from JUST the sun and exposure. It's more likely to happen if a new expert sands a factory finish.
So yeah, I get it you didn't sand it, I was just using your clearcoat failure issue to make a point to all the people that will read this into the future as I never type for the present but always for the future.
Currently the situation is light and I can "live" with that. Is there a way to keep the clear coat from further failure with maybe waxing without fixing the current clear coat failure?
From what I saw in the pictures, not much you can apply topically to stop the disintegration that's already in progress.
There's this,
Patented UV Protection - Optimum Car Wax - by Dr. Ghodoussi at Autogeek.com
Get it. Use it often. Keep the car out of the sun and the rain as much as possible. Water is a universal SOLVENT. It breaks things down.
If not, i have seen a method to slightly sand the area of and near the clear coat failure and spray it with new 2k clear coat spray. What do you think about this method?
Thank you
I've never tried it and I've read success stories and horror stories.
I think it comes down to in part - how much basecoat you have and how much you have to scuff it in order to clear it. The basecoat is even thinner than the clearcoat so too much sanding of scuffing and you alter the color of the car.
The next issue when it comes to success or failure I think comes down to the person and their skill and ability to take on a project like this.
