Jeremy1976
- Apr 13, 2015
- 978
Got this from Nick yesterday and my car was due for a wash. I took it to the coin op and pressure washed off the heavy contaminants and any road salt.
Got it home and mixed up my 1 gallon sprayer for a pre soak. 1 ounce per gallon. I then mixed 1 ounce per 2 gallons of distilled water per instructions. I immediately noticed the suds. The only other comparison I have is Wolfgang Uber RW. That does not sud at all. I also find the N-914 equally pleasant smelling to the WG!
Laid out a nice layer of pre soak while I had 6 Eagle Edgeless towels soaking in the 2 gallons of solution. Got right to work!
I noticed the lubricity to actually be a little more than the WG when gliding the towels along the panels. With little to no effort the panels wiped clean. I used very light pressure, as I always do, and no different than when using WG.
My quick conclusion with only 1 use is it is definitely on par with WG which I consider the leader in RW's and a top shelf product. Smell is pleasant, directions are straight forward, lubricity is high, ability to clean is stellar!
I always like to get some time with any new product before I vouch for it. So I will be rolling with this and will be doing a bucket to bucket, panel to panel comparison with the WG. I will update when I get some more seat time. For now and with initial use this looks to be a home run for Mckee's!
Hope you all are well!
50/50 wipe
All done with my partner tonight!
Sent from my SM-G935V using Tapatalk
50/50 wipe
