mixmaster209
- May 22, 2009
- 112
Hi everyone,
Just got my flex 3401 last thursday. This thing feels really well built. Now just one question...
Before I use it for my first polish and wax, i had searched alot on this forum and others regarding what I should do when I had heard about the whole backing plate issue.
I feel bad creating a whole new thread about this, but I have searched for more recent threads and posts about what i should do to make sure this doesn't happen with mine. I had read that people put oil on the felt ring and tighten the bolt of the backing plate. Now, the first thing I did when i got the Flex was tighten the bolt of the backing plate because when i called Bobby from Autogeek, he had said all you should have to do is follow the instructions in the manual and tighten the bolt holding the backing plate. He also had mentioned that the backing plate issue happened a while ago and that I shouldn't worry or have to do anything out of the ordinary to have a perfectly running flex 3401. Now, I was wondering if anyone hadn't oiled the felt ring and run into any problems. I didn't really want to remove the assembly and start removing things and oiling them.
I figure its a new machine and should I have to do this? Am i risking anything if I don't?
Basically, has anyone not oiled the felt ring on their recently purchased flex 3401 and not had any problems?
Also Might anyone have a picture of the felt ring. Is it as simple as taking of the backing plate bolt and removing a felt ring?
Also could i use motor oil, as that is all that i have at the moment.
Thanks again guys for your help. And yes i did use the search button..lol
