Just some thought's and observation's about Car Wash Soaps
DLB
There has been more than 1 thread on the subject, so I thought I'd make this one for open discussion.
I made this chart a while back for a thread where someone was looking at various soaps. This list is sorted by price per ounce. I don't have the numbers for dilution for every soap shown, so this is just a hard number price - not price per application.
There may be something different now as this is a few months old. I also think there have been a couple of soaps added that don't show on there.
I know that price doesn't always justify buying one soap over another - but how many soaps in the top half of that chart have you heard just pure negativity about? This brings me to the conclusion that spending a lot of money on soap is not really necessary. I didn't say that you should buy the cheapest, but if you do a lot of washing, I don't see being able to justify spending $3.00 an ounce (or even 7 times as much) more just for the soap.
Now don't get me wrong, the more expensive soaps may be a great product (I haven't tried all of them), but how justifiable are they for regular detailing use?
I see it like this - you need one of the following:
a) A pure wash with no other properties.
b) A strip wash that will clean all the old stuff off.
c) A foamy wash that can be used in a "gun."
d) A protectant wash that adds something to the paint while you wash.
e) A rinseless or waterless wash.
Maybe I am missing one (or more). Following that thought process, if a soap does it's job of safely and effectively cleaning the dirt (most important aspect of its job), then if it has other properties and it completes those tasks successfully, why would you ask for anything more out of a soap?
Right now (the majority of the time) I am using Meg's Shampoo Plus (will post a review when I get more washes with it done). Reason being, it is effective at cleaning the paint for the steps that follow, and it is cost effective. I am using it as a pure wash with no other properties. I don't care if it leaves a shine behind, or anything else, because I am following the washes it used for with polishing or waxing. Now, I do plan to step up the cost scale as it seems reasonable and try some others that I never have for comparison sake; but as of right now, the Shampoo Plus is doing a fine job.
Also, I remember a video from a while back that Mike P. made about washing (couldn't find it - maybe someone else has it bookmarked). He thoroughly covered most aspects to washing a car. One such aspect was "lubricity" of the soap.
The point really is this - the suds represent that the soap is sudsy, that's it. The lubricity (the critical part for not scratching while wash) is all in the formula of the soap. Think about it, you are mixing your soap with water. You want the water to become very slick, because this is what is coming in contact with your (or the customer's) paint. The suds are just a by-product. This is of course talking about a traditional wash, not a foam bath.
The way that I mix my wash solution up is intentionally to get the best mix of the soap into the water, and NOT create unnecessary suds.
•I fill my bucket up with about 3 gallons of water.
•Then I pour my soap in and calmly stir it into the water, mixing the two together to form a soapy water solution.
•Then I top off the wash with another bit of water to have plenty of wash solution, and this also mixes up the solution a bit more.
What you end up with is a very slick, soapy wash solution without a lot of suds. Suds do very little to clean and to protect your paint from getting scratched. In fact, if you look at how this chemically works, pouring your soap in and then blasting the bucket with a water hose could be doing more harm than good. What you are doing is taking the liquid form of the soap and turning it into suds. You then have less liquid soap mixed in with your water. The water has then become less lubricated than if you had no suds.
These are just my thoughts on the matter, and not scientific fact that I can prove.
Others?
[/end book] :D
DLB
Has any one used the DoDo Supernatural? why such a crazy price? is it worth the money?
One thing you really need to look at more, which negats your $/oz, is dilutin ratio. DODO Juice SN only needs 3 mL of soap/gallon...thusfor a 3.5 gallon wash (about what i use) it only cost, using $25/250mL pricing) brings it to apx $1/wash.
Which is close to other prem car washes, and maybe even cheaper in the long run, i.e. buying the 50 mL.
As with everything look at the full picture not just price per oz with products like this. For thing such as polish sure..but wax is the same way...some use alot per application some use hardly any. Best pricing guide is price per application for most detailing products.
Taken from another site:
Duragloss 901 is according to the label, diluted at 1 oz (a fluid oz is 30ml) per US gallon 3.78 litres. That is a dilution rate of 1:126 with water. I found it for sale for 5.99 GBP for 473ml, or 1.27p per ml.
SN shampoo is dilutable at 1:1500 with water. This is 11.9x as concentrated as Duragloss 901, according to both manufacturers' recommended dilution ratios.
SN shampoo costs 12.95 GBP for 250ml, or 5.18p per ml.
Because you would need 11.9x as much Duragloss 901 to wash your car as SN shampoo, it would cost you 1.27p x 11.9 = 15.11p per ml equivalent.
This means that in real terms, SN shampoo is 2.91x CHEAPER than Duragloss 901.
I use DG 902 (901 in a US Gallon container) which is the largest and most economical way to buy DG901.
DG902 3,780ml @ £26.55 from glossmax
SN 500ml @ £23.95 from Dodo
I use 8ltr water per wash
I use 2 pumps of DG, but going by their exact dilution it should be 62.5ml
SN would require 5.3ml
DG will last 60 washes
SN will last 94 washes
DG cost 42p per wash
SN cost 26p per wash
Now even if you use the smaller (slightly) less economical SN bottle, round up the SN dosage to 3 squirts (6ml) and take account of the free delivery i got from glossmax on the DG; SN would still work out cheaper.
Prob the best way in looking at soaps, is as above.
One thing you really need to look at more, which negats your $/oz, is dilutin ratio...Best pricing guide is price per application for most detailing products.
Absolutely - but the time it would take to give the cost per application is WAY more than I have. If someone at Autogeek feels froggy and wants to post the dilution ratio's then it would be downhill - but for the sake of showing simple numbers, I think that will suffice. I edited my original post to reflect that the numbers shown aren't trying to show price per app. Thanks for mentioning. :xyxthumbs:
It (the chart) isn't meant to be a tell all know all - just a baseline.
Also, this thread isn't just meant to be a price debate - but rather a general look at soaps and how they are used and their effectiveness.
DLB
If I get some time this weekend I will try to do a cost / gallon of water spreadsheet.
This assumes a 3 gallon wash.
Column headings
List price, oz wash per gallon of soap, washes per gallon, cost per wash
CG Maxi Suds II 12 1 42.7 0.28
Meguiars GC 12.49 1 42.7 0.29
DP Auto Bath 45 0.33 128.0 0.35
Adam's Car Wash 30 0.5 85.3 0.35
Mothers 18.18 1 42.7 0.43
Poorboys 40 0.5 85.3 0.47
Griots 40 0.5 85.3 0.47
Pinnacle 70 0.33 128.0 0.55
DG901 25.15 1 42.7 0.59
Optimum 30 1 42.7 0.70
I was surprised about Optimum being high but for most people (excluding volume detailings) all washes are cheap as anything.
I found blue tape is one of the most expensive products a detailer can use in a per application.
Sorry about the formatting. It seems tabs nor extra spaces are retained.
Am I the only one that uses DG902 at 1oz per 2 gallons? I have found that at the recommended dose it seems way too frothy and thick.
1) Anyone used it? I have and not a fan. I tried this using a 1 gallon bucket and followed the recommended dosage of 1 pump per gallon. Terrible. Added 2 more, not impressed. Followed with 3 more pumps (6 at this point), not bad but still not impressed.
2) Crazy price? I'm assuming because it's from the UK. That's all I've got on that!
3)Worth the money? Not in my opinion. I want and will try more soaps. I have used Meguiar's Gold Class for so long because it works but recently tried Meguiar's Ultimate Wash & Wax. This stuff is impressive. Super slick water but if you add a heavy stream, lots of suds!
