Karcher K1700 vs Sun Joe SPX4000
czaredd
Was about to pull the trigger on the Sun Joe SPX4000, did a little more research and ran across the Karcher K1700. My intentions are to use a foam cannon and I'd like to know which one I should get. From what I understand, the Sun Joe doesn't use standard accessories....you can only use Sun Joe quick releases, etc. Based on that alone I was thinking that the Karcher is the better machine BUT the PSI and GPM are lower than the Sun Joe. Can I use a foam cannon right out the box on either? Will I need additional accessories? This pressure washer will be primarily for car washing every week and the occasional driveway cleaning. I'm stuck....any help would be great! Thanks
The new SPX3500 sunjoe I have uses standard fittings now. I love mine so far.
Nice!!! This will be my first pressure washer and from what I understand, having standard fittings is a major deal. Thanks
I just picked up the SPX4000 and my dusichin foam cannon doesnt fit. I'll be the first to admit that I know nothing about fittings and such. No idea what to do and how to attach the foam cannon. Frustrated.
Sent from my SM-G950U using Autogeekonline mobile app
