keeping a dust free car (almost)
dchristo
I read here a few weeks about GROUNDING your car so static electricity wont attract dust...well I thought I would give it a try.
my truck sits under a carport and gets very dusty within a few days.. but after grounding its been almost two weeks and very little dust:wow:
:checkit:
picture.php
picture.php
I used a alligator clip so if I forget to unplug when I leave, it will just slip off
Interesting, could you get a shot of how\where the wire is attached to the truck under the hood\behind the bumper? This might be a good trick for my car.
:checkit:
picture.php
picture.php
You should try both!
Interesting, could you get a shot of howwhere the wire is attached to the truck under the hoodbehind the bumper? This might be a good trick for my car.
I just hooked it to the neg battery terminal
I personally like the idea of charging my car from the post. I now wonder if it would work with an inside 2X4 upright? You were using a 4X4 or 6X6 which I would think carry a lot more charging power; love the whole green example....sorry..could not resist :xyxthumbs:...BTW--love the idea--very creative.
So did it work? I know on another forum there was a pro detailer (fixed location) who would ground the cars to a water pipe so they didn't build up static from all the microfiber rubdown.
Grounding is from the metal plate and not the size of the wood.Im the MAN
:checkit:
picture.php
picture.php
Glad this grounding system has been effective and has worked for you, even though I don't see a 'good ground' from your pics.
Being that local NEC rules along with the local AHJ's will vary somewhat between municipalities:
Can't tell if your carport is a "poured concrete over a re-bar system" (NEC recognized UFER grounding system) or not.
Also...An NEC recognized 'grounding rod system'; or 'grounding' to a munincipal water supply line (except for PVC lines, of course) are other sources to 'ground' to.
If there were a lightning strike in your area that goes to 'ground', I would really worry about the placement of the alligator clamp lying upon the bumper of the vehicle, with such clamp attached to the "wire" leading to the battery.:o
Attaching this "wire" to the vehicle's frame would be a better choice, IMO...especially if the vehicle is parked close to the house.
Once again...great creative idea...but I would definitely make sure of a proper 'ground'. That's just me and how I feel about electrical 'grounding'.
Just a few concerns I have....nothing personal. :)
This is pretty cool. I may have to try this out at some point.
Bob, the metal where the wire is hooked goes 3 ft in the groung
the negative terminal is grounded to the frame ( Battery to frame )
BTW, I am a journeyman electrician :xyxthumbs:
