Hi Everyone!
I'm pretty new at car detailing, and enjoy doing it for fun, mostly on my family cars.
Would you please review my work/photos, and let me know what i did wrong here? The result i got is not satisfactory...
On the bright side i did NOT burn through the paint
My Ram 1500 2013 truck Maximum Steel color tailgate got keyed pretty bad about a year ago, and I've been preparing to try to do fix on it by myself - done lots lots of research and decided to go for it! Why not...
If i do a "nail test" on the scratch, the nail definitely makes sound and it seems that they got all the way to primer in most areas of the long 4ft scratch.
Here's what i've done:
1. Wash/clay the tailgate, used IPA 96% to clean the scratch. See photo attached "before work done"
2. Filled-in the scratch with 3 layers of touch-up paint that i got from dealership, 30 min dry time between each layer. See photo attached.
3. Next day, added 2 more layers to completely fill-up the scratch and tried to put a bit of a hump over it. Let it dry for 15 hours.
4. I set-up my PC polisher fitted with 3inch back plate, 3 inch Meguiar's Foam interface pad, and 3in Meg's Ungrit 3000 Finishing sand disks
I began carefully sanding the scratch on 4 speed with spraying little of water and wiping off clear coat residue. I was careful to not burn through the clear or the paint. (i think that maybe i should have done it more and leveled the surface a bit more...) but it was all a guess since i have no way to measure paint thickness. See photo.
5. After i was done sanding/leveling. I used my PC with 3in purple LC-58-4235 wool pad with Menzerna SI1500 which took out the 3000 grit sanding marks in seconds and made it glossy again.
Once i was done with buffing, the scratch felt almost glass smooth if i run my nail over it - so it seemed like surface was leveled pretty well... not super perfect though.
However, as you can see on the picture, the outline of the scratch is clearly visible again, and it's sort of shiny/sparkly... It looked better before i began sanding/leveling as the scratch looked dark at least, and did not stand out as much.
Would you please analyse my approach and let me know what could i have done better to get better result?
Questions:
1. If i wait longer between the layers, what would that do?
2. I was working outside, it was about 50 degrees cold. Is this significant for paint drying?
3. There is very very little information on the forums on doing wet sanding with a PC/3 inch pads. Most definitely no info on wet sanding with PC when repairing deep scratches - any big reason not to do this? Everybody fixes these by hand wet sanding. Why??? so much faster/easier by PC.
4. Should have i went further and keep sanding/leveling the paint until it's super glass smooth?
5. Maybe the scratch is visible like this because my paint color (Maximum Steel) has small reflective pieces in it that shine when on the sun? Looks like they the shiny pieces all lined up together in the scratch now lol... maybe i should have used different darker touch-up paint instead of my original one?
6. How much apprx would it cost to get tailgate repainted at a shop?
7. Would it have helped if i tried to also hand sand into the scratch to try to smooth out the sides/edges of the scratch?
The stupid scratch did not bother me for past 1.5 years, now it's bothering me because i did not get the result that i was hoping for. I'm debating if i should get the tailgate repainted at a body shop.
Is there anything else i can try to make this scratch less visible? Re-do whole procedure again?
Thank you all very very much for any feedback! Looking forward to learning what to do and what not to do, and WHY
Questions:
