KLASSE AIO by Machine or by Hand
RWC32
To all you Klasse fans, do you apply AIO by machine or by hand.
What pads work for you?
Do the results vary between the two?
I've applied both AIO and the glazes by hand with NO problems. Just wondering if there is an advantage to using a machine for the AIO.
Thanks in advance -
If you are applying as an LSP then a finishing pad would be my choice......the only advantage IMHO would be speed of application.
I thought I heard that when you machine polish it will pull more dirt, not sure though.
I've only applied KAIO by hand. Always had excellent results.
Moisten the applicator pad, apply thinly one panel at a time, then wipe off.
I absolutely love this product. I haven't applied by machine yet so I'm curious to see opinions on this.
