Klasse AIO, HG sealant, & Collinite in one weekend
cc rider
Ok. So, Im getting ready to do up my vehicle for the winter. I see that the sealant can be applied right after the AIO. Then there is a 12 hour wait. Finally I can apply the collinite wax. I got the 476. Im going to clay first of course. Im just wondering what happens if it rains in between. Should I try to get it all done quickly. I dont drive the vehicle much so if it rains while the sealant is curing should I just wash it again then apply the wax? Thanks
You could always do 2 coats of KSG and be done. That should get you through the winter.
Won't the polish help to clean, prep,remove swirls,etc?
Polishing helps to clean, prep and remove swirls. Polish aggressiveness matters. Not all polishes can remove swirls.
Sealants and waxes 'seal' or protect the good work of polish.
Hope this helps. :) :)
KAIO is more of a chemical paint cleaner. If you want to remove swirls you will need a polish with some abrasives.
KAIO is a chemical cleaner, but it stands out from the other cleaner products cause it actually removes some pretty decent hazing similar to a finishing polish. Its kind of hard to define Klasse AIO, I sometimes doubt there isn't some sort of abrasive in it.
Werkstat Prime also removes a lot of haze. That one will even do it by hand.
Pretty interesting products.
I feel the same way about KAIO, the few scratches/swirls I do get on my car between polishings are readily removed by it.
As for your question, if it rains on the car between the Klasse SG and the Collinite, yes, a light wash of the car would be advisable. Rain water can contain pollutants (some worse than others depending on where you live) that you don't want rubbed in or sealed in next to your paint.
Even though Klasse All-in-One is a chemical cleaner and have no correction capabilities, you'll be pleasantly surprised how gorgeous your paint will look after using it. Klasse all-in-one used in conjunction with a white foam pad speed 4 to 5 will produce spectacular results!
Klasse's High Gloss Sealant provides a near bullet proof protection and designed to be used atop of their all-in-one cleaner.
Tip
Pour some Klasse's High Gloss Sealant in a spray bottle to apply. A light coating on the finish or the cloth to apply for best results.
Thanks everyone forgot to mention, its a black truck (2014) so the paint isnt bad.
