Klasse All in One
camryse2014
I absolutely LOVE this stuff! I ordered the small 10 oz. bottle on Amazon after reading this review here ( Klasse ALL-IN-ONE Auto Polish, Klasse All In One, klasse aio, Acrylic polish ). I used to use Meguiar's / Turtle Wax but it would get so sticky and take forever to remove. This product comes on and off so easily, leaves the paint feeling so slick and smooth, and really makes the paint come alive. The small bottle also lasts forever because you only need a nickel-sized drop for each panel. I highly recommend it in anyone's detailing arsenal.
Here she sits shortly after the Klasse AIO. I apologize for the crappy cell phone picture quality.
Great job! I see by your post count you're new here. Welcome! Just a heads up...no linking allowed to outside vendors. Also, the price of Klasse AIO is cheaper here at the Geek Store than that store you linked above. ;)
IMO:
You'd love this stuff even more if you'd use
it in conjunction with Klasse High Gloss
Sealant Glaze (K-HGSG)---the other half
of the "Klasse Twins" combo.
Stuff has been around for a while. It has no correcting ability, but good fillers to make things very hard to see. Great to put on cars that are in good condition cars, or u wanna shine up a friend's car without doing alot of work
I found many good quality of car polish at the expensive side. Most of those polish creams are too costly for me. After washing my car, I apply coconut oil on my car. Upon coming back to my garage, I find lots of dust particles to be stuck on my car body.
i found many good quality of car polish at the expensive side. Most of those polish creams are too costly for me. After washing my car, i apply coconut oil on my car. Upon coming back to my garage, i find lots of dust particles to be stuck on my car body.
lmao what
Same thing happens if you use WD-40
What brand, Hawaiian Tropic? :)
As Bob mentioned, the real magic of the Klasse products is when they are used together, i.e. AIO and SG together. I've never used AIO by itself, but I'd be comfortable in saying you'll get far more durability out of the SG than the AIO by itself.
The stuff does last a long time. I have the bigger bottles I bought over 10 years ago, and I'm still not done...although I do admit I don't use it as often as I once did.
Epic first post. What do you use when gasoline is too expensive?
Thank you for all the input. Can I use a spray liquid wax on top of the Klasse AIO?
Back in the day KAIO was used under everything. Under KSG, under any sealant, I used it under Z2p all the time instead of a proper decon, put it under a wax and the wax lasts longer ect.
People used it to strip old stuff to try new stuff ect. Try it with a slightly damp pad, try cleaning the rubber trim with it, not so much the plastic though.
Yes, I believe there was some discussion about adding KSG to a QD and convert it into a quasi spray wax. I could be wrong on this but a little searching will prove my statement one way or another.
Typically with AIO's I like topping them with Optimum Spray Wax. This product along will last 2-4 months easily as it is not your typical spray wax.
Klasse AIO's purpose in life is more to provide a base layer for SG than it is to be a stand alone product. Since it cleans the surface and leaves a little acrylic sealant behind, it sets up the surface for just about anything you'd like to apply afterwards. I never paired it with anything other than SG, but don't see why other products wouldn't work.
There is a formula floating around where you mix SG with something else, maybe a Meg's QD of some sort, to make a spray wax. If you're going that route, you might as well use the Sonus Glanz which was designed to be a booster for SG, or the Sonus Spritz which is a QD compliment to SG. Personally, I'm not a fan of the Glanz, but do like the Spritz.
The Glanz was the mixture put into off the shelf form.
I have used the sealant on top of a coating and it makes the surface extremely slick.
HUMP
Cook up some burgers for lunch and you have FREE oil to apply! ha
