klasse sealant glaze
kimchiboi777
It says to only use on painted surfaces. But is it okay to use on my headlights for UV protection? Thanks,
autogeek_2235_70785292
Klasse High Gloss Sealant Glaze provides high impact acrylic protection that lasts for up to a year!
Klasse High Gloss Sealant Glaze is a highly concentrated acrylic formula glaze for new cars and oxidation-free surfaces. Klasse High Gloss Glaze provides an additional protective layer over the All-In-One with an exceptionally brilliant mirror-like shine.
Klasse High Gloss Sealant Glaze creates an elastic, non-chip, shrink-proof, heat and scratch resistant - protective seal against ultraviolet rays, salt water, acid rain and industrial pollutants for up to 12 months. Use this glaze on all paints with or without clear coats, glass, fiberglass, Plexiglass, plastics, metal surfaces, enamel, tiles, Formica and all non-porous surfaces. It is anti-static, non-abrasive and contains no ingredients harmful to paint, metal or plastic.
Klasse usa ,Klasse Application Guide, How to apply Klasse AIO, Klasse High Gloss Sealant Glaze, All-in-one, klasse all-in-one
I've used Klasse on different brand auto headlights, Ford, Lincoln, Volvo. Used Megs plastix plastic polish, Klasse AIO and then High gloss sealant. Stays clear and seems to last many months. But, nothing is forever.
I never had problems using Klasse on lenses (both headlight and taillights).
Makes them sparkly (especially red taillights).
Thanks all, one more quick question. Down the road, when I go to reapply the sealant glaze, how do I remove the original application? Does simply washing the car remove the KSG?
I would wash as normal, then use Klasse AIO to re-prep the surface and lay down a "starter" layer of the selant. AIO is a chemical cleaner, and since it's also the Klasse sealant, won't interact badly with the KSG.
KSG (silver) is darn durable and will last months on most all surfaces. You can reapply a second coat for longer protection. Then consider a spray like Sonus Acrylic Spritz to keep it going and looking glossy.
