DFB
- Aug 12, 2019
- 4,594
- 2,366
Koch Chemie All-round Quick Shine, Quick & Shine, Quick Finish and Finish Spray Exterior
Koch Chemie offers four different quick detailers in their current lineup, of which it’s hard to know what the difference between them is. From the product descriptions, they all sound identical, but digging deeper reveals where each one sits.
All-round Quick Shine, Quick & Shine QS –
These two are the same product, verified by the MSDS. All-round Quick Shine is from the blue bottle consumer range, while QS is from the white bottle professional range. You would expect the larger 1-litre pro bottle to cost more, but it's actually $5 cheaper. Go figure.
This is another product I had overlooked, mainly because I was already stocked with quick detailers and happy with my selection, Meguiar’s Last Touch and P&S Paint Gloss. All-round Quick Shine was a product I won in a monthly giveaway and ended up pleasantly surprised by it. Most quick detailers are idiot proof to use, All-round Quick Shine is no different, just spray on and wipe off, job done. The great thing about this type of product is how they boost gloss and slickness without overdosing the paint with protection. It took me a while, but I’ve become quite fond of its scent, one used across many KCx products.
Quick Finish –
This is the silicone-oil free version of All-round Quick Shine and QS. I’m guessing this would be aimed at the body shop industry, a competitor to Meguiar’s Final Inspection or P&S Paint Gloss C51. Like the two above, Quick Finish will leave behind some very mild protection, most likely removed at the next wash.
I found Quick Finish to be just as easy to use, but it doesn't quite reach the same slickness and gloss as QS.
Finish Spray Exterior FSE –
This version is somewhat unique in that it’s a combination quick detailer and mineral remover. I really have no use for this so have never bothered to order it. From what I can tell, you’d use this as a drying aid to neutralize high TDS water after washing.
How To Use –
All three of these are used like any quick detailer, so I’ll let the following cover each product.
1. Wash the vehicle as usual.
2. You can apply prior to towel drying, or after using a blower to remove the bulk of the water. Three to four sprays per panel.
3. Wipe with the panel with a drying towel, flip or use a second towel and wipe till streak free.
Usage Notes –
- You will need to order a sprayer for each of these, except the blue bottle All-round Quick Shine.
- All four can be used on ceramic coatings, waxes and sealants.
- With the exception of FSE, you can use these as interior detailers as well. In this regard, they are excellent on glossy trims.
- Avoid using on hot surfaces, especially FSE.
Final Thoughts -
Unlike many, I still think there is a place for detail sprays like this. They are easier to use, won't overload the paint with "protection" and are kinder to your towels as well. Thing is, we seem to be conditioned to think that adding "protection" at each and every opportunity is somehow a good thing. I'm not quite sure how we ended up to the point where the term "drying aid" should mean the use of a paint sealant after each wash. I'm guilty of this as anyone, but it's getting a bit out of hand.
Of the four above, unless you are dealing with hard water, I'd probably rule out FSE from this quartet. I'd also rule out the silicone-oil free Quick Finish as doesn't reach the same gloss and slickness levels of the All-round Quick & Shine and Quick Shine. Choosing between those two, the 1-litre bottle of Quick Shine makes the most sense.
Quick Finish –
How To Use –
Usage Notes –
Final Thoughts -
