La Bella Putana: 1977 Alfa Romeo Iniezione
richy
La Bella Putana indeed. This gorgeous red Alfa Romeo was slated to get dressed in her best...her Finest in fact. I made an interesting discovery during my journey with this car that I'll share shortly. This was to be and inside and out job, although I did not shoot the inside. This car is a re-paint from many years ago but the paint was in good shape and had lots of it. Let the fun begin!
Here it is as it arrived to me:
She had the perfect plate:
I thought the bumpers were rubber like the old Porsche's at first glance, but it turns out they were metal and were painted in a flat black colour:
The paint on this car turned out to be a big challenge:
First up as always was the wheels. I went to my BAM wheel cleaner and sprayed it on dry and let it dwell and then agitated. I actually found a car on which I could use the smallest of my set of three wheel woolies. I swear I have never used it before, but it was perfect for getting into the channels of the wheel. I then used Zep Citrus on them and 3D Pink soap. The tires were cleaned with Zep 505 and the wells with LATA.
The top was cleaned with a wash mitt and Pink soap as well and the rest of the car got the same. It was then brought inside and was clayed with a clay towel.
Now it was time to play with some paint! The hood was badly and deeply swirled. I used Shine Supply Chop Top again and definitely needed that level of cut. It was combined with a TB black wool pad. That was followed up with a yellow B/S pad + M205. I then did one step further than usual and followed that stage up with Essence + CarPro Gloss Pad. All polishing was done with my 3401.
I was happy with the results I was getting and had done the hood and front fenders. Then I moved onto the driver's door and discovered this on my TB wool pad:
Single stage paint! Are you kidding me? It seems the front half of this car was painted in base/clear and the back half with single stage paint. How the Hell does that make any sense? The SS paint was a PITA to polish and coat. I forgot how much I disliked it. It corrected easier than the B/C, but I don't like the mess it makes of everything.
Once polished, the wheels and paint and side glass were treated to a double coat of CQF. The windshield was double coated with Fly By 30. The exhaust tips were coated too. The convertible top was treated with DG 342. The interior was vacuumed, wiped down with a damp mf with ONR and then the leather surfaces were treated with UIGP. I hand polished the wooden steering wheel. I regret not shooting that. It was sealed with a DG beta product I had. The tires were shot with OB from my air gun. Be forewarned, I shot lots of pics of it as I was both proud of it and also when I first took the shots it was cloudy, but then the clouds broke and it really showed it off, so I shot some more.
Here she is, 20 hours later all done:
Reflection of cloudy skies above:
Two with the top down:
This was a very cool car to work on and I felt honoured to have the chance to do it. As always, comments are appreciated. Thanks for looking.
Awesome little car. Great job bringing it back to showroom condition :)
Stellar work Richy! :props:
Interesting combo used there Richy, was there any difference in results during the 205 & Essence steps being that part of the car was SS or nothing to note? Was Essence used as a visual "gloss enhancer" & if so - after 205 was there a marked improvement Richy? Or was Essence used as a primer for Finest?
Results are phenomenal Richy, actually looks quite at home parked there too mate. Great post, thanks for sharing. :dblthumb2:
Aaryn NZ.
It's a beautiful thing that you did richy. Great job as always.
Strange that part of the car was base coat/clear coat and part was single stage paint.
I am also interested in your answer to Aaryn NZ's post.
I remember that car here in the US as simply an Alfa "Spider"; was it only called Iniezione in Canada? Oh, wait, I just looked that up and apparently that means "injection" in Italian, so I guess it's fuel injected, and I guess it was a "Spider Veloce" here. Anyway, thanks for the memories--particularly those Pirelli P77 tires which I had a set of a hundred years ago--one of the first all-season tires, and had an asymmetric tread pattern: https://books.google.com/books?id=y...qBm8Q6AEIOjAI#v=onepage&q=Pirelli P77&f=false
Great job as usual, Richy.
Thanks very much. She was blown away by the transformation, so that made me very happy.
Phenomenal work on that little roadster Richy! Impeccable!
Thanks for sharing.
Thanks very much Mike, and I appreciate you taking the time to comment.
Nicely done Richy!
Thanks kindly Frank.
Aaryn NZ.
Thanks kindly Aaryn! I like to use Essence prior to using a CP coating, although it's finicky for me sometimes. Where I've had the best results are when I use it after 205. It both amped up the glow (it was not a huge difference, but it was there) and also helps a bit with the bonding of CQ is what we are told. The SS paint benefited from it just like the B/C did. The look of 205 followed by Essence is incredible. I would definitely do it on my own car and when time permits on customer jobs, I'd do it too. That's often not the case however.
great job Richy
Thanks for commenting Mike, see above for that answer.
Thanks! I immediately thought of it as a Spider too when I googled Iniezione. I laughed when I saw those tires->they look like snow tires!
Niiice! That SS with the BC would've thrown me for a loop. But you made it seem less buddy.
Thank you for the explanation Richy. :xyxthumbs:
I was hoping you were going to say exactly what you said. I've done a few jobs of late where I wouldn't normally do an extra step but for some reason one day I chose to do that extra step & I chose to do it with Essence. Pinnacle Advanced Compound - Pinnacle Advanced Swirl Remover then Essence. Now the compounding finished off really nice & long story shorter I chose Advanced Swirl Remover over Finishing Polish & that finished down beautifully . . . Essence was used for an unknown reason but the results were breath taking. I thought I was over thinking it & it wasn't as different as I thought so when time allows I too have been doing an xtra step with Essence, Wow! Extreme Gloss Enhancer for sure! I have even managed to catch it in a photo.
Anyhow! Awesome work on the Spider Richy, stunning results from first class workmanship.:props: Very interesting thread.
Aaryn NZ. :dblthumb2:
Don, thanks very much for your kind words my friend.
Aaryn: Glad to hear it! I actually discovered something using Essence on the next car that I'm anxious to share.
:xyxthumbs: Looking forward to that Richey.
Aaryn NZ. :buffing:
