Lake Country 4 inch ?
ronpirate
OK.... Is it me or are things confusing enough with polishes/waxes/etc.?
What gives.... LC white in 4 inch waffle is more aggresive than Orange pad. Not in the 5.5 and the rest of the lineup of their pads. If this is so ... then someone in LC marketing Dept should be taken out back and given a what for... Anyone got a clue as to what is up with this....... should not be a big deal... but it drives me nuts....
Thanks...
I hear ya. It is sort of counter intuitive that different pads from the same manufacturer are not all color coded the same way. My best advice is to stick to one or two lines of pads and stock the colors you use most.
IIRC the LC Waffle Pro order of aggressiveness is:
white > orange > blue > gray
