Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Lake Country 8.5 inch Hook & Loop DuroWool Twisted 100% Wool Aggressive Cutting Pads
Classification:Cutting Pad
Yarn: 100% Twisted Wool
Pile Length: One inch
Cut: Very Aggressive
Working Face of Pad Diameter: 7 1/2 inches
Tool: Rotary Buffer
Attachment: Hook & Loop Interface
Backing Plate Surface Diameter: 6 inches
Recommended Backing Plate Size: 6 inches
Purpose: Removing deep below surface paint defects. Removing sanding marks after wet-sanding.
Method of Cleaning: Spur or Pad Washer
Lake Country’s Wool Cutting Pad is made of 100% wool twisted into hundreds of individual strands. The tight twisting allows the pad to operate at a consistent level of aggressiveness for longer periods. The pad has a diameter of 7.5 inches but the thick pile gives it an overall diameter of 8 inches. The Wool Cutting Pad is intended for severe swirls, scratches and heavy oxidation.
On the Autogeek.net Store
Lake Country 8.5 inch DuroWool Twisted 100% Wool Aggressive Cutting Pad
On the left is the 41-005 7.5 inch pad, on the right hand side is the 41-005 8.5 inch pad. Note the difference in overall size..
Working Face of Pad Diameter = 8.5 inches
1 1/2 inch Pile Lenght
Outer edge pile length trimeed to 1 1/4 inch
This is what the twist looks like when a pad states it's a twisted wool pad. You can see groups of yarn fibers are twisted together with other groups of yarn fibers to created a single strand of twisted yarn fibers. This is the most aggressive design of yarn fibers and this makes for the most aggressive design of wool buffing pads.
The center section is left void of yarn to help prevent swirls.
The longer the pile, the easier it is for the twised yarn fibers to lay down horizontally against the pad as your work the pad. This ability to lay down makes the pad less aggressive than a shorter pile buffing pad.
On the left is the 41-005 7.5 inch pad, on the right hand side is the 41-005 8.5 inch pad. Note the difference in lenght of yarn fiber.
The Backing Plate Surface Diameter = 7 inches
Copyright ©PBMA - Autogeekonline.net® All Rights Reserved
Tool: Rotary Buffer
