Lake Country CCS 6.5 pad repair ??
jmj540
I have two Lake Country CCS foam pads, the velcro backing totally came off one and the other pad is halfway off. Both pads are not that old and in great shape. Has anyone used a adhesive to read glue the velcro backing ? I thought using 3M trim adhesive and try to save the pads. Let me know if anyone has a trick or a good adhesive to use, the pads still look new and have life left in them. Thanks!
I had the same issue, used some adhesive glue which held up for a while.
All of my yellow LC flat pads have done this, but I have not tried to fix them. All my other colors of the flat pads are holding up well.
Reading through the forum , I did see one post saying that a hot glue gun works well to bond the velcro backing back to the foam pad.
I've had the same issues. I have like 12 left each of the yellow and orange. I think once they are gone I'm switching. Even had one of their wool pads blow up
This is ridiculously timely: I came searching for exactly this issue as I have two orange SONAX 6.5" pads with the cloth backing coming off this past weekend. The foam is still in great shape, but I have a hard time controlling the pad placement on the car with half the cloth coming unglued. My Lake Country white pads have been holding up fine.
I have access to a hot glue gun at work; how heavy/thick an application are you suggesting?
I was doing a search of the forum and found one member had used hot glue to bond the velcro back together, he didnt say how much or what kind of pattern.
I have used 3M spray trim adhesive glue to a couple of pads, but one is ready to let go after some use. I have seen anything from gorilla glue, super glue, and hot glue listed. I love the 6.5 CCS pads, I just ordered 12 more, but I would really like to save these too, much more life left in them. It alomst looks like some kind of rubber cement type of adesive used to bond the velcro to foam. My orange pad had the glue peel off of the backing pad in one piece,
( it was funny , the foam took off and I couldnt find it anywere, two days later it was on the roof of my other van, Im a T-7 para in a wheelchair, my neighbor asked me, "whats that orange thing on your roof....lol.).
I always wash and set them face down to dry, and use a rolling pin to exrtract any excess water. I also found out that twisting up the pad to dry and hot water seems to be bad on a pad too. I still think this is the best pad for my needs.
Guys really. A pad is less that 10 bucks. Now I'm not a rich guy by any means but is your or a customers paint really worth chancing on having that pad come apart while buffing. I use Lake Country pads exclusively and have never had one do that. Maybe you are bearing down too hard and causing too much heat. It's not always how fast you can get the deflect out. Iv'e worked in the car industry fro 39 years and you're going to pay about 500 bucks to paint a panel by a good body shop.
WAXOFF:
Point well taken re cost, but for me that's not really the issue. Whether it's $10 or $20 or $100, I have this naive expectation that any product is going to work and perform as advertised with "zero defects"; if/when it doesn't, I'm disappointed. That's the case for me with these pads that appear to have failed long before their expected life span. Was hoping the combined intelligence of the community could lend some insight as to whether I'm using or maintaining the pad incorrectly and causing my own problem; or whether this is a brand/product issue that is par for the course. Perhaps if I were a professional, I'd shrug it off and move one as you do; but without 39 years of experience, it becomes noteworthy on my learning path. I'll take your comment re "bearing down too hard and causing too much heat" as a possibility and pay closer attention to that.
I have not tried it but wonder if something like 3M Foam & Fabric 24 Spray Adhesive might work, or a similar spray adhesive.
Not to sound degrading to you. I was just trying to make a point that whether it was user error or a defective pad I would contact the manufacturer to see if may there was a bad run of glue on that certain pad or maybe they could give some insight. I have heard of having a pad slightly damp can cause a steaming effect when it gets hot and starts to degrade the adhesive also. My only point was don't try to use something that could compromise your work and cause some worse to happen. It's kind of like buffing out a deep scratch and I'm sure we have all done it before. you thing just a little more and then the clear is gone in a instant.
There is a thread somewhere around here about some of the LC (flat pads I think) pads delaminating and that was probably just a bad run of them.
I should have mentioned that mine are mostly from user error. Too much polish/compound, too much pressure, moving the polish to slowly or dwelling in one spot, and/or to high of speed(Duetto).
Here are the worst ones.
One definitely over heated/saturated. The one half folded back is too, just not as bad. It's sunken on the face in the center. One "like new" just with the loop side cleanly gone. The other on is in decent shape, just a little coming loose around the edges.
Has anyone tryed contact cement or rubber cement?
Spread a little on each surface, let dry till tacky and then
join each side together. I would think that would work,
however I have no experience with gluing pads.
Jim
