Lake Country Chart Inconsistencies
BlueBeast14GT
I'm comparing pad descriptions from different sources. They're all similar, but there are strange differences, sometimes within the same website.
For instance, for the 4 inch gray LC CCS pad, AutoGeek recommends "Use with machine glaze or finishing polish." Then for the 5.5 inch version of the exact same gray LC CCS pad, AutoGeek says "apply thin, even coats of waxes, sealants, and glazes."
But the most glaring inconsistency has to be from Lake Country's own comparison chart. Every single other source says that green is less aggressive than white, but Lake Country's Pad Application Guide says that green is the more aggressive foam.
Even Lake Country's page describing types of foam seems to contradict this. Assuming the types are listed in descending order of aggressiveness from purple to gold, then it is consistent with their application guide. But, if you actually read the descriptions it says that green is "Semi-soft , high strength foam for light polishing" while white is described as "Semi-firm, high strength foam for polishing." This description makes white seem like the more aggressive foam.
The only other potential source that is in line with the Lake Country application guide would be Chemical Guys. If CG uses LC foam in their Hex Logic pads, then their aggressiveness scale would match Lake Country's Guide. But, I have no idea if this is the case, and no reason to think it is other than a similar coloring scheme.
Little differences in descriptions are no big deal. But I would really like to know what is going on with the green and white pads.
Edit: Here are 2 more charts from Lake Country to add to the confusion.
  1. D.A. Foam Pads
  2. Spot Buff Pads (this one doesn't even have green!)
I understands what you mean it really confuse most especially the ones who are new, and trying to learn though like I have discovered you gotta pick, and choose pieces of information from all to come up with your own answers....that's why is great to have a place like autogeek
Yup. That's why I brought it up. I figured someone might have the answers through experience. And, I wanted to warn people, new or experienced, who might be misusing the pads based on incorrect information.
I think I'm going to try calling Lake Country later to see if I can clear this up.
At one time there were two green foams, one was for German cars or something (or was developed for use in German car plants). One was more aggressive than white, one was less. Hopefully that helps on the green (good luck identifying which is which, especially if you have both in your bin like I do).
There were two green at one point. The more aggressive of the two is now pink. Hex Logic uses a different foam, but similar color scheme.
The LC pink is similar to Hex Logic's Green - cutting/polishing. The LC green is similar to the HL blue - light polishing.
I'm aware of the euro foam green, but this is not it. That green was below orange on the list, above yellow. This green is between orange and white, according to LC.
As was previously mentioned, I believe that green that was between orange and white is now pink.
Specifications - D.A. Foam Pads | Buffing & Polishing Products From Lake Country Manufacturing
Lake Country CCS Pink (was Green) Heavy Polishing Pad
This pad is is used by Mecedes Benz at OEM level and is designed to be used with a random orbital polisher (like the Porter Cable) It produces less spot heating and has a unique compression/load/deflection ratio which means it conforms quickly to contours. It is a high strength foam with 60 pores per sq. inch yet is softer and more forgiving than our regular foams which have 80 pores per sq. inch.
This pad is tough enough to remove swirls and scuffs whilst at the same time producing a high gloss swirl free finish. THis foam is also ideal for applying one-step cleaner waxes. It is a balance of polishing and finishing that is perfect for all-in-one product application.
- Quoted from a UK vendor.
And AFAIK this only pertains to the CCS line. The Pink was the old coarse green pad. It fell between the Orange and White pads. The soft green pad fell between the white and black/gray pads.
Right. Due to confusion, Lake Country changed the color to pink.
Well then, now this is even more interesting... I know they had listed that green as more aggressive than orange because I found this chart. I'm hoping it's okay to post that since they're part of PBMG.
So either one of the colors (euro green or pink) was placed in the wrong spot on the chart, or they changed more than just the color.
Either way, this still doesn't change the fact that LC lists the current green pad (not euro, not pink) as more aggressive than the white pad, and every other source has them switched.
I tried calling LC, but no one answered. I left a message, but so far no one has called me back.
Normally Dave@LakeCountry is on here to assists with these questions.
This week is AutoMechanika (German version of SEMA) and Lake Country has a booth set up there with a few employees including Dave.
Give him some time and I'm sure he would be happy to address your concerns. :xyxthumbs:
Yeah I figured they would get back to me eventually. Good to know though; thanks for the info! :props:
By the way, I called Chemical Guys, and the foam used in the Hex Logic pads is their own.
Sorry for the late reply.
We have had many changes to our foams and the chart of aggression.
We are in the process of updating our chart(s) and website as a whole.
This may take a little, but it is happening.
For a while, products were added or removed, product lines were launched, and all we did was just keep adding new items.
Foam colors are specific to their "line".
All orange foams are not created equal. For example we have many oranges and all are very different - H20 tangerine, Hybrid orange cutting, standard orange/ccs, Constant pressure even has a different orange.
When comparing aggressiveness in foams it needs to be done carefully because of this.
Also, with different types of machines, and even polishes, the term Aggressive can mean many different things. Please let me know if you need any explanation. I will plan on doing a blog about our foams and aggression to help, and will link to a new thread on AGO when I do.
Chemical Guys does sell Lake country pads, but we do not make the hex logic pads.
They do not make any the foams themselves.
If you need help or have any questions at all. please email @ [email protected] or give me a call @ 262 367-8395
David, thank you very much for the explanation! I had no idea it was that complicated. My Lake Country pads are all CCS, so far. And thank you for providing your contact info. I'll have to shoot you an email later with my specific questions. :xyxthumbs:
