fejcharson
- Jul 24, 2015
- 62
Should I get the Lake Country thin 5.5 pads or the thinpro to go with my gg6? Thanks I just don't know if I should spend the extra 15.
I'd get the 5½" flat pads, and a LOT of them!
Wouldn't worry about the yellow ones, probably never need them. But you DO need to get AT LEAST 4 orange, 4 white, 2 blue, 2 black to start. Also... the 5½" CCS pads work just as good on the GG6. They'll spin just fine, and they'll go around corners, into irregular surfaces etc. and maintain pad to paint contact.
With the CCS pads they have a green one that's really soft, is lighter weight, but has more cut than the white ones. It'll compress REALLY easily, but it cuts well.
Wouldn't hurt to have some red ones just for snits n giggles. Might have some soft paint you want to really ramp up the gloss on, or just use them for wax/sealant spreading. You'll literally never get all the sealant washed out of your pad(s), so you'll need to dedicate a couple for that application.
(I tend to use the black CCS pads to spread sealant FWIW. That or red flat ones. Then clean by hand, let air dry, and store in a Ziploc bag.)
I'm going with the flat pads should I get 2 yellow 2 orange and two white to start or 3 orange 3 white. I have some 6.5 but am switching to the 5.5. Thanks for the help.
So skip out on the yellow?
