AutowerxDetailing
- Apr 10, 2012
- 2,791
I was getting everything ready to really test out these new Waffle Pro Pads from Lake Country and I started thinking... Why not let YOU decide how to test these puppies out?
Here is the plan: I have a small assortment of compounds, polishes and tools. You ask me the questions, I will deliver the answers with photo or video proof of the results.
Example: How do these pads work with a rotary polisher at a particular speed? How squishy are the blue pads compared to the black pads? You ask the questions and I will find out and update this thread accordingly!
To kick things off let's review some basic information about these new pads.
Lake Country Waffle Pro Foam Pads, buffing pads, compounding pads, polishing pads
Lake Country Waffle Pro Foam Pads have a convoluted "waffle" design that allows air flow between the pad and the paint. This increased air flow prevents heat buildup and skipping. The work surface stays cooler and the pad glides over the paint more easily. Lake Country Waffle Pro Pads are available in multiple sizes and foam compositions to suit all your detailing needs.
The Lake Country Waffle Pro pads are available in the following colors:
White Compounding - The white pad is dense and firm. Use this pad with an aggressive compound to remove serious paint defects such as sanding scratches, deep scratches, oxidation, and weathered paint.
Orange Heavy Polishing - The orange pad offers excellent versatility. Use this pad with a polishing compound or medium grade polish depending on the level of polishing action you want to achieve. It will remove severe compounding haze, deep swirl marks, and weathered paint.
Black Finishing - Use the black pad with medium grade polish to remove light swirl marks and light compounding haze. Use this pad with a finishing polish to create a high-gloss, swirl-free shine.
Blue Finessing - The blue pad is exceptionally soft. Use it with a finishing polish to create intense gloss.
The Lake Country Waffle Pro 6.5 Inch Foam Pads can be used with dual action polishers or rotary machines. Use a 5 or 6 inch backing plate with hook and loop fasteners. Each pad has hook and loop backing securely adhered to the foam, making pad changes quick and easy.
Let the interactive review begin!! :buffing:
