mwoywod
- Apr 3, 2016
- 881
I know this question is around 7+ years late, but I'm hoping some of the forum members that have been around for awhile can offer some feedback.
I work on a lot of restored classic cars that have been repainted and the orange peel is almost always bad enough that it's impossible to see any resemblance of a reflection due to all of the coats of clear (which is a good thing!)
Depending on the job and paint hardness, I typically finish with 3,000 grit
For the initial cutting step after damp sanding, I use the LC thick purple foamed wool pads with my Dewalt 849x rotary because for the past year I've worked in an environment where all of the lint from traditional twisted wool pads is just not really a viable option. I've found that the thick foamed wool pads are great, but occasionally just aren't quite aggressive enough. So my question is....
Does anyone have experience correcting with a rotary and LC 6" lambswool leveling pads? I've search the forums and it seems like most guys are using them as the cushion for their bonnet when removing wax which the concept of using a machine and a bonnet to remove wax was a real ### moment for me. But the reason I'm so interested in these lambswool pads is because I've been trying to find famous "Edge-Lambswool pads" and I found a post that mentioned the LC 6" lambswool actually being the exact same pads just without the black dye? Can anyone confirm this?
Also, if any of you have a recommendation for what you believe the best cutting low-linting wool pad I am all ears!!! Thank you!!
