Layering sealants?
andrew b
Does anyone bother to apply more than one coat/layer of the sealants like DGPS, Blackfire, etc?
I know folks still top with various waxes, but before I do that I'm wondering if I should do another layer of DGPS....
Thoughts? This is on a Monaco Blue BMW, using DGPS and topping with (probably) Pinnacle SigII...
The only sealant I layer is UPGP. You only have to wait 45 min between coats. Other than that, it's only one layer for all other sealants.
I layer Blackfire Wet Diamond and Wolfgang Deep Gloss Sealant with great results. Just be sure to wait at least 8-12 hours.
Two layers for me, just to ensure that I've not missed any spots - but then again, unlike I would guess most here, I don't layer waxes on top of sealants.
The Monaco Blue color is the base coat. You won't, hopefully, be applying any LSP's to the base coat paint film.
Polishing/leveling/'correcting', as it were, the clear-coat paint film is the true way to allow the Monaco Blue color to "shine" through the clear-coat...being at it's best reflective hue. In other words the clear-coat is deemed to be 'clearer'.
Once you've attained, to your satisfaction, the clear-coat 'correction', you're goal should be protecting the clear-coat with an LSP that will, upon curing, also be clear as possible.
The steps taken to achieve the above will allow the Monaco Blue to "shine" through now, what I consider, two (2) film coats....
-One (1) being the: As clear as you have made possible, to your satisfaction, from being 'corrected': Clear-coat paint-film
-Two (2) being the LSP applied upon the clear-coat that hopefully has cured to be clear also.
You don't want an LSP occluding the 'corrected' clear-coat right off the bat....When an LSP has begun its march towards its end-of-life cycle..It will begin to occlude the clear-coat paint film, causing the Monaco Blue to seem "not so shiny" as before...not as clear, because the clear-coat paint film is occluded/grayed-out.
If you desire to layer more LSP's atop the original LSP (#2 from above)...
I will only suggest to try the: "Cure-Clear" analogy. That's what I do.
I did two coats of WGDGPS on my truck for winter. Didn't top it with anything else.
I also did two coats of WGDGPS on my mom's car before winter, but topped it with Fuzion. This was mainly because I really wanted to try out Fuzion.
Come spring/summer I'll probably only do one coat of sealant and then top with a wax.
This is really just my personal preference.
Wow, that's a heck of a response! Very detailed and informative.
I've layered several different sealants this past summer with complete success. Some of the sealants I used were;
  • Prima Hydro-Seal
  • Klasse High Gloss Sealant
  • Wolfgang Deep Gloss Pint Sealant
  • Werkstat Acrylic Jett
  • Ultima Paint Guard Plus
  • Detailers Pro Poli-Coat Paint Sealant
Wait 12 hours between coats and you'll be fine....:props:
Same for me 99% of the time.
For Sky I wait hours to re-coat but anybody else its 45 minutes now.
3 coats of UPGP look fantastic on my honda...a candy look
I've layered 2 coats of Megs ULW one right after the other then a 3rd a week later. No issues.
I stopped layering sealants. As long as you are meticulous with your application and don't miss spots, layering a sealant has shown me no durability gains.
I put 2 coats on just to be safe...One ofMenzerna (left the Men.at brother-in-laws) and a coat of Blackfire....looks great..
I've read that some people have done 40 layers of ksg
I got up to 3 then said the heck with it...
KSG is one of a few products that seems to layer, 3 seems to be the magic number, after that you don't seem to get much out of it.
yes, this is what made me think of it. I used to do KAIO x2, and then KSG x3 (or more). for me, 3 was about the right number, after that you couldn't really tell much difference.
Just wondering if the new (not the quartz) sealants also benefit from more than one layer....
