LC backing plate question
emmjay
Member
Hello all,
I've been looking at the changeable backing plate system from LC and I have ordered it. I've seen posts about the shims and the problems with the 6" that were rectified and detailed instructions on how to install on this forum. However, I have not seen any instructions about assembling the 4" plate. From what I understand:
Step 1: Remove the stock BP, washer and bolt and set aside.
Step 2: Take the 4" plate, gear, SUPPLIED bolt and washer and assemble.
Is this correct? So for the 4" plate I use the supplied bolt and washer and not the stock one that came with the flex?
Thank you :)
You should be fine with the supplied bolt.
Check out this video from the guys at Lake Country.
[ame="http://m.youtube.com/watch?v=jQEGQZpua7Q"]Lake Country Flex XC 3401 VRG Backing Plate System - YouTube[/video]
I have no issues with this system. You should be fine and the Lake Country Video is perfect!!
Yeah I watched that video twice just to make sure :P
That's good to hear. I was just weary about which screw/washer to use.
Thanks guys :dblthumb2:
