Leather Belt stain removal from white leather
juicegoose
For the life of me i can't find anything to remove the brown belt stain from a leather seat. Need advice
2024 Ram Limited with off white leather interior.
Drivers seat has a darkened spot at belt level from brown leather dress pant belt.
I've tried lexol with a white cloth - No change
Detail guys leather cleaner - no change
LA Awesome & a scouring pad or a damp magic eraser
If you use the magic eraser apply very little pressure
Even this might not work, but you'll only be out $1 if it doesnt
Good luck
I was thinking of you earlier
If you choose to use the magic eraser wear gloves before soaking in la awesome. You probably don't want that stuff in your blood stream is what made me think of you. If you've already done it and develop a cancer forget you ever heard of me
You really have nothing to lose (except the $1 previously mentioned ...)
Keep in touch
I agee with Flash, but I would try Magic Eraser with water first before soaking it in LA Awesome.
1Z - Einszett Plastic Cleaner.
It removes transfer like that off with zero mechanical agitation...
I would choose this vs. a Magic Eraser....but I suppose a Magic Eraser you may have on hand available...
I have qualms even using my Ninja Scrubber on leather surfaces
I wonder what this fellow ever ended up doing?
Experience tells me that you never want to get white interior
The best color combo is silver exterior, with black or navy blue interior
Morning guys i appreciate the reponses for sure. Im going to try the magic eraser in a small spot today to see what it does.
Ill try the plastic cleaner after that.
This was my first white interiorvehicle and I still love the look. I just think it will take more care than say a black interior.. what do you all recommend as a protectant if I’m able to get the stain out some sort of ceramic coating
