Leatherique application
NiSyam
Hello guys,
Once the Rejuvenator oil had enough time to work the seats, should i remove it before using Prestine clean ? Or just apply prestine clean on top to the rejuvenator?
Thanks
pristine is a cleaner not a topping. you will need the pristine to clean the soiled rejunevator off.
+1, although Leatherique say that PC leaves some protection behind, it's main role is to clean the RO from the surface.
After this PC can be used as a maintenance cleaner.
Also I think you would find it quite hard to remove RO without PC as it becomes quite thick & sticky.
When I used it I let the RO soak, sprayed the leather with PC, agitated with a soft brush, wiped with a hot, damp towel then dried with a clean, dry towel.
