Let's see if Solution Finish will hold up
kb2ehj
Member
Tried Chemical Guy's Tire & Trim Gel about a month or two ago. They claimed up to 8 months of durability....well didn't last two weeks and i was back to gray trim again.
This time I'm trying Solution Finish, some YouTube users are claiming 6-12 months of durability. Well lets see what happens.
Prep'd and applied to the plastic per the instructions that came with the product and now we just sit back and see what happens.
View attachment 60525View attachment 60523View attachment 60524
Top it with Dlux and you will get 6-12 months for sure, providing your prep was good.
Prep was a scrub down with APC, water rinse, the sprayed with IPA then applied
Looks good.
You can top it with another product like wolfgang exterior trim sealant. Works very well. I have moved back to a trim sealant after hearing Chris West talk about coating plastic trim on a podcast.
Looks good.
mike, if you don't mind me asking... what downsides are there about coating plastic trim that chris west mentioned?
Chris mentioned that the coating clogs up the pores of the plastic at the microscopic level. Meaning it could "block" solution finish from penetrating into the plastic the next time it's time for another round of solution finish. I believe he mentions that trim sealants don't penetrate into the plastic like SF but sort of sit on top.
I believe it was in this episode where Chris mentions it.
looks like at around the 21:48 mark. thanks for the info!
That makes no sense? If I clean and prep correctly, apply SF correctly and it supposedly penetrates into the plastic then covered with a coating. Shouldn't the coating be the first thing to go away/wear out before another application of SF is needed? Just asking / thinking out loud again.
I'm not a plastic expert so I can not answer this. I refer you to the video where Chris West talks about this. Visitor was kind enough to note the minute mark.
The Forensic Detailing channel on YouTube says you get longer durability if you apply 2 coats. You certainly get a deeper black. Mine is going strong at 2 months.
I would put a 2nd coat of Solution Finish on the plastic trim before applying a trim sealant or trim coating. Solution Finish is the perfect product for restoring you plastic trim.
kb2ehj, if you are curious about a good comparison you may want to avoid anything else on top of Solution Finish. I'd be curious to see what you get for durability. But again, if you're tired of something not lasting, by all means, do what you want to do to extend its life.
Maybe 2 coats as recommended above but you can consider that when evaluating durability.
I agree Paul A. I have not dismissed anybodies ideas or suggestions, but for this go around I'm going single coat with nothing on top. I hope to remember to take pictures at probably 30, 60 and 90 days out.
So far, one week out, I'm really liking it.
Both prep and application was a breeze and will be a goto product if it work - even if it only lasts 3 months.
So by the end of the podcast, Chris West actually turned you off to his own product? Interesting..
Btw, I've listened to that podcast at least twice.. Once when it 1st came out, and again on your recommendation and I didn't come out of it learning anything groundbreaking or anything I didn't already know.
It's been a while since I listened to that episode, but does he touch on petroleum distillates at all? I'll go out on a limb and assume his product doesn't contain any? [I assume that since it says it's silicone free, but who knows]
... But back to petroleum distillates. I did a 50/50 test a while back between Meguiars Ultimate Black lotion and AA Outlast Trim Restorer... Here's what they looked like a couple of days after applying, both looked good. [both those products contain petroleum distillates]
But the strange thing I noticed long after the test concluded, and after both products were long gone was that the center untreated strip ended up looking way better and the 2 sides that had once been treated with products ended up looking even worse than they ever had. It's like those products [and other similar products] actually degrade/destroy plastic in the longrun?
The only thing that may have factored in is the fact that the particular trim I applied it to is hard non porous plastic found on Toyota Tacoma... But regardless, both products left it in worse condition than before, once they wore off.
-Sorry for hijacking your thread, but I wasn't sure if this was ever worthy of its own thread so I just posted it here.
The problem is SF has trouble penetrating the coating (Dlux) and causes a splotchy and uneven look. I had to use Ultimate Compound to remove the coating before applying SF again. So maybe applying two coats of SF may be a better solution, no pun intended.
Well it's been 15 days and I must say Solution Finish is still holding up rather well. Not as dark black as when first applies, but still looking good. It appears you can not attach pictures thru the autogeek app. I'll post pictures later
Download the Tapatalk app if you want to post pictures. It works on there.
