Ryan Bishop
- Feb 12, 2016
- 42
Buffed and polished and waxed and I'm seeing light web scratchs only at night up really close in the day time up close it looks fine.
I'm used a To makita buffer but I tried my new boss is it a bit longer in process using a orbital?
Need more cutting and patience.Buffed and polished and waxed and I'm seeing light web scratchs only at night up really close in the day time up close it looks fine.
Im with you on that,rotary punches and knocks swirls out very quickly,but then you have to repeat to get the halo out with a pc or orbital.some situations you can just use the long throw,it depends on paint condition and hardness and most importantly the time allowable to give the finished product back to the customer in a timely manner.sometimes you can split the tool.use the rotary on hood and trunk then redo whole car with long throw.Your doing double work but the swirls will be gone.Im not a buffer guy who has to buy the latest and greatest,at the end of the day you get the same results.I'm used a To makita buffer but I tried my new boss is it a bit longer in process using a orbital?
