I do not have either one but my understanding is that the paste is made for darker colors while liquid looks nicer on lighter colors. It depending what color the Ferrari is. If it is red, go for the paste version.
Use SSII for lighter colors if you perfer a paste.I do not have either one but my understanding is that the paste is made for darker colors while liquid looks nicer on lighter colors. It depending what color the Ferrari is. If it is red, go for the paste version.
Souveran paste is best used on solid colors with a higher reflective nature already (black, reds, yellows). SSII was designed to focus on all other colors and works extremely well on metallics too.
Either or would look great.so would red metallic (Spice Red Metallic GTO) be best with Souveran paste or SSII?
Applying every other week is redundant. Although paste Souveran is a beauty wax and will give you 4 weeks, why not use Souveran spray wax or Crystal Mist between waxing. Liquid Souveran should not be layered because of the solvent content that will only remove the previous layer. Again, use Souveran spray wax or Crystal Mist between waxing for more pop and durability.Is there a limit to how many layers I should put on? That is, if I am using it every other week, will I begin to get a hazy finish or less shine in the appearance of the paint?
I am also wondering about letting it dry, does it not say to do it section by section? I thought perhaps it was not supposed to fully dry?
thank you again for your help.
I have received and used Crystal Mist, it is beautiful. Are Souveran spray wax and Crystal Mist basically one and the same? The ingredients described seem very similar.
Crystal Mist is a quick detail spray designed to remove small amounts of dusts ,fingerprints ,etc. Souveran Spray Wax is all wax - No cleaners
