Little Green Machine
Nuke33
I'm thinking about getting a little green machine, do you all use the sock nozzle for it or did you get any attatchments and if so what work the best?
Ryan
I've had one for a long time. It was a hand-me-down so it only has the standard spray/suck nozzle. It works well. I like it alot. Now; to be honest you can probably do the same job with a spray bottle or two, and a good wet/dry vac. I keep using the LGM because I feel that I'm saving the filter on my wet/dry vac.
I had one and returned it. I like a shopvac better for the way I do things.
Well my parents are getting it for around the house too
That would be a great idea for them to do!
I had a Little Green machine too. Used it once, then the nozzel clogged and could never get it to spray again. I did rinse it well after the first use, took it apart, all no good. Went to the dumpster.
greg'sgoat said:
If only Edge would make somthing like this to work with their quick adapter. I would be all over that.
somebody get aaron on the phone, now! :D
Ryan
Don't buy one. I got one I will give you, she old but run like a champ! Let me know! PM me.
