Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
Live Broadcast Video - 1965 Plymouth Valiant - Extreme Makeover
Paul's 1965 Plymouth Valiant 100
This is a recent resto-rod with a new paint job but there are still holograms left from a wool pad on a rotary buffer. This is a great candidate for an "Extreme Makeover". It was originally a straight 6 but now it has a warmed-up 318 made to look like the 273 high performance engine that came in a 1965 Plymouth Barracuda Formula S. This is only the second paint job this car has ever had and there are only 42,000 original miles.
Here's what the paint looks like in the sun....
Swirl City!
We're going to remove these swirls and create a true show car finish!
Here you can see water spots and swirls inflicted by a rotary buffer...
Holograms inflicted by a rotary buffer...
More holograms in the paint on the hood and everywhere throughout the paint...
This is a cropped out section from the above pictures so you can better see the water spots in the paint along with the holograms...
Holograms and water spots on the trunk lid...
Far shot of the passenger side with the sun reveling the swirls in the vertical panels like the B-Pillar...
Ouch! Kind of hurts your eyes to look at this...
Sun's too low to really show the swirls but you can kind of see them, point being is they're there and we need to remove them...
This half-circle scratches are from machine sanding, they're called pigtails...
As you can see the paint is filled with swirls, scratches, water spots and even pigtails from machine sanding.
Our job... remove the defects and restore a show car finish...
First up will be our Test Spot, that's where we'll dial in a process that removes the defects to take us to 95% or better correction.
Swirl City!
