Long Term Ceramic Coating Storage?
ejaf
Member
Has anyone been able to successfully stored an open bottle of ceramic coating over a year?
Curious, as that will affect my next purchase choice of which one to get, or whether to just go back to a sealant (tried to store Mckee's 37 in fridge to reapply to a vehicle previously coated last year, and ran into what I would call, "sticking" issues).
TIA...Eric
Pinnacle Black Label paint coating does not harden in the bottle.
Other coatings may harden in the bottle once opened.
I think all good coatings will harden in the bottle. If they don't how do they protect the car like they say they do?
IMO the curing is inevitable and will happen, some will be faster, some will be slower.
Interesting...I would tend to agree with that statement...
@Guz - you've noticed no issues regarding the Pinnacle coating after prolonged storage?
I received used IGL back in February. Not sure how long they were open at that point.
In August, I finally went and used it. Both bottles had formed some solids, crystal like stuff? around the threads of the bottle/cap. I was careful when I opened it, and took a damp towel to remove those bits before I tried applying it.
Hasn't seemed to affect performance, but it's too early to tell.
Yes. I have over a dozen plus that are stored in my garage. It gets hot in the summer but is heated in the winter. Never had any issues. McKee's is the only one I have had a problem with but I've since moved to storing them in old CarPro or GYEON dropper style bottles and have no issues with it now.
Are you saying that you have stored Mckee's for longer after switching the bottle?
I had tried to store them in a plastic bottle, sealed with Saran Wrap around the threads, yet had issues with removal.
Here's what I stored them in...could be I didn't flip over to this method soon enough, however:
I use empty ones from the other manufacturers. See the image linked to there.
Pinnacle does not harden like a typical coating in the bottle or the applicator itself.
It may work to put nitrogen in from welding supplies just an idea put in ballon first then slowly flood open coating bottle to displace normal air ... or helium
Get your point...I could also purchase a cannery and utilize their vacuum machines as well ;)
Another great idea by Mgavin. The less headspace (where air accumulates) the better
I buy my coating bottle at glass bottle bottle outlet I don’t use euro dropper I use pressure cone style fill up to bottom of neck the pressure cone style is air tight I buy coating in liter option from Japan and transfer to 30 ml.
Is this what you mean by a "pressure cone" style bottle cap?
E
Yes so you fill up to slightly above bottom of bottle where liquid starts going into neck that leave little air left. When you screw the top on it compresses that little bit of air. When screwing cap down there should be resistant that how you know you have enough liquid in there. If there is no resistance you need to put more liquid in. When there is enough liquid and the compression of the air push back you get an amazing seal you have the cap screwing on the outside of the bottle and you have cone seated by the pressure on the inside of the bottle.
mgavin...I can't thank you enough for your experience on this.
Here I am worrying about 50ml of liqud, and your going through this 1 liter at a time!
Curious...do you keep the liter amounts refrigerated when not in use? Or should that not matter, providing the seal on the bottle is air tight?
Air is your enemy {oxygen cause oxidation and degrades things, how ironic). I work on oncology drugs and I overlay the active compound with nitrogen ( in a vial, with the least amount of headspace)
Same goes for coatings in containers, the less air the better
