Long Throw Polisher Proper Technique????
ski2
We sometimes hear of members unhappy with their Rupes polishers and the response from many is that you need to "practice the proper technique" for effective results.
So what is the proper technique when using a long throw polisher?? How does it differ from a conventional 6 or 8mm throw polisher??
I have a G15 on the way from AG's sale last week and want to start off on the right foot.
I think the only real differences are the priming and frequency of pad changes.
Only prime the pad with a few drops of polish so it doesn't slung all over the place when your turn the machine on.
Change pads often to avoid heat build up. Keep 6-8 pads handy and rotate them out after each section.
Also, you don't need the heavy down pressure you do with conventional polishers. The long orbit does most of the work.
Ski2, well you nailed it. I have asked this question over and over again - see my recent thread regarding my Rupes vs Flex experience. I have seen a one clip of the rupes on curvy panel video a while ago (i can't remember but it wasn't very helpful) and it only showed the tip of the polisher on the curvy panel. Try doing that on 1/2 the car.
http://www.autogeekonline.net/forum/flex-polishers/92511-flex-first-time-experience.html
Better for the experts to comment but my experience was that the technique involved angling the polisher (and to some extent the pressure) so that it somewhat sits flat against the panel. And then using the tips of the pad to polish the panel. That may work for some but clearly not for me.
For flat horizontal panels you will not have any problems. However, anytime you have a curvy/vertical panel (especially a door that is convex or concave) I believe you will get very frustrated and wind up spending huge amounts of time trying to get the polisher to spin. I know I did and I had the whole Rupes line. After a while I scrapped it. I hate to say this but maybe you should return your newly purchased G15 and just buy the Flex. The whole issue of "technique" goes away, just polish in record amount of time with excellent results.
If you stay with G15 please post your experience and if it works your technique.
This thread is interesting because I've just got into using and getting down The Kevin Brown method with my Porter Cable. And now I just got a Duetto coming soon. So it will be interesting to see what adjustment if any I will need to make with the Rupes polisher.
I use the Mike Phillips method (he is who I learned from, watching his videos and taking his class). I have used a PC7424XP multiple times and recently got a Rupes LH21. I didnt change my technique from how I was using the PC and it worked just fine. I didnt have a problem with pads coming apart or anything. I was even able to use the Rupes around curved edges just fine. Its a DA, it will stop spinning if the pressure is uneven like any DA will. Its a matter of keeping the tool balanced and let it do the work.
IMO, It's really just a matter of adjusting pressure, tool/pad angle, and/or increasing tool speed if needed. Make a mark on you're backing plate so you know when it's rotating and if it happens to stall on a curved panel section play around with the amount of pressure and adjust pad angle until it rotates. I forget who it was that said this, but I agree with them 100%....They said that those who started out on a rotary will probably have a better idea on how to approach these areas as the way you need angle the machine is very similar. Once you get the hang of it you will just naturally adjust without even thinking about it.
Over the winter, I practiced on a test panel in the basement. I have a mirror set up for me to monitor my posture while drumming.
I moved the mirror so I could monitor my technique on the test panel with the 3401, 7424xp, and the Duetto. I noticed that I had a tendency to lower the chassis of the machine a tad, which had a direct impact on the performance of the 7424xp, and Duetto. With that new revelation, I was able to transfer that awareness to the vehicles I've been polishing this season, and it's significantly expedited my overall time, and made working with the Flex that much smoother.
Well after reading this I guess I'm going to hold off buying another polisher. I did have some issues with my PC-7424 stopping but I've been able to master it using the edge (1/2 to 1/3) of the pad in order to keep it spinning and/or using smaller pads when coming across curves, if that doesn’t work I play with the pitch and roll of the polisher (for lack of a better description).
I've done a full orange peel removal with just a PC-7424xp and some denim pads (took forever). That project is what got me wanting a Rupes 21 or a Flex 3401, but now that my major correction is done I won't be doing much other than spot compounding scratches and re-polish (as needed).
I was really hoping the Rupes 21, Flex 3401, or Boss 21 would cut my working time enough to offset the cost of the tool but as I’m just a hobbyist detailer with perfect paint I doubt I’ll be polishing/compounding very much unless I start taking on friends cars.
Oh well, more money for go fast mods!
This is also what I believe in, i coudn't have said it better. Just to help you more ski2, in using the machine effectively, you should understand how was it designed and its concept of paint correction.
Remember, unlike other orbital polishers, this has a longer throw. And this long throw together with enough pad rotation will be enough to remove paint defects. Having said that, as rasky has mentioned, your technique should be focused on maintaing the rotation of the pad, by varying pressure, angle of the pad touching the paint surface.
Unlike my GG6, or other conventional orbital short throw polishers, applying pressure while maintaining pad rotation (bump up the speed) gives more correction power.
With rupes, you dont need to apply so much pressure just to get more paint defect correction. Hope this helps. :dblthumb2:
So basically technique with a long throw polishers is the same as a standard 8mm throw polisher, but the pressure needed will be somewhat less.
Thanks Guys!!!
You know, you seem to jump in every polisher thread these days bashing Rupes claiming this, but I have a problem with it that you need to explain. If you had "the whole Rupes line" Just what about a Duetto couldn't you get to work either that you had to sell it at the "huge loss" you've claimed in multiple places? Something doesn't add up here. I think you'll be hard pressed to find either a Mini or Duetto owner that won't say they're the best tool in their class, which means you either are trolling or you may really have a understanding of usage issue. If it sounds like I'm calling shenanigans here - I am. Something doesn't add up.
First, i tell personal offense to your comment. I am in no way trolling or trying to bash Rupes. My whole point is that you need to have to learn technique that is no where filmed or explained all that well. I just read The Flex book and the watched the Flex video - where is the Rupes video and books, since I would love to learn how these tools work.
I think I am very technically inclined and tried like hell to make it work. Maybe you are that special and have it down, but when I got the Flex I really saw how much easier it was to polish and actually enjoyed the experience. As for shenanigans, my loss was real and I have the invoices to back it up. For example Order ID W-810253 placed 06/06/2014 and many many others will show you the costs. If you want all the rest I can send them to you since I don't like my integrity questioned.
Further and finally, I am trying to assist others in that if you care not to learn the special technique and just want your ride properly maintained in a manner that is done quickly and as easily as possible, my thoughts and comments may apply to you. If not, please ignore them. I have gotten many PMs saying they appreciated and agreed with ALL my comments. So for me at least, if someone wrote what I wrote I maybe wouldn't have went down this expensive disaster.
So please refrain from questioning my integrity otherwise you are showing what an a-hole you are.
Thanks for the a-hole comment, I think that's giving me a better appreciation of the source. That said, you didn't answer the primary question. What is it about the Duetto and Mini that wouldn't work for you that you had to sell it at a loss?. Let's not let your panties in a bunch obfuscate that question.
I dont understand people who say Rupes are not good polishers because they stop spinning. If they stop spinning on curves then you dont know how to use the machines. I use my Rupes, 15, 12, 75 everyday for corrections and the machines never stops spinning for me. You need to learn how to make adjustments. Once you figure it out, Rupes are a pleasure to use. My Flex hasnt been used in almost a year, if that says anything.
I don't own either, Flex or Rupes, but I am in the market for a polisher. From my reading on the forums and product reviews, it seems like people are very divided about these two tools. Many have both and some acknowledge the usefulness/benefits of each, but many say that they stopped using one after buying the other. Some complain about the Flex being hard to control while others say it is very easy. Others complain about the Rupes stalling all the time while some say it hardly ever stops. I still find most of the comments useful as they usually atleast menton some of the most common pros and cons of each tool which helps each person decide for themself which tool would be best for them. Ideally I think a person would try each before buying, but for many that isn't an option and relying on the thoughts of those using these tools regularly is the next best thing IMO.
I don't know what happened with my Duetto yesterday. No pressure, and it would rotate backwards, light to moderate pressure, it would sit and shake. Heavy pressure, it rotate slowly in the proper direction.
I was using their yellow foam pads. One with m205, and one with their Keramik polish... kind of dumbfounded, because I've never had this happen before.
This used to happen with my Craftsman 5" variable speed d/a palm sander. Eventually I got the hang of it. I assume the same will happen with the Duetto. I'll be practicing with it again today.
Normally I'd try and figure it out, but time constraints dictated the 3401 step in to handle the rest of the job.
