Looking for a compound that offers slightly more cut than 3D One
Bri26
Active member
What compound would you recommend that offers slightly more cut than 3D One? I want something that I can go to if 3D One and a microfiber cutting pad on a 8mm DA polisher isn't getting the job done. Basically, something for hard clear coat. I'm currently looking at Jescar correcting compound and Sonax CutMax but open to other suggestions. Thank you
I use Griot's Fast Correcting Cream but be warned. If you are using a microfiber pad you will have to go behind with a finishing polish.
Sent from my SM-G988U using Tapatalk
I put a few up against 500 and CARPRO Ultra Cut and The Last Cut+( LAST CUT+ was the strongest)
3d 510 is my compound of choice. 3d 500 is good as well but never tried with my pads since i dont use those. Never used 3d one.
Back when i first started and used my megs mt300 free spinning da, megs d300 compound with thier mf pad work really well together. Very under rated. Finished down really nicely.
