Have you tried dying the spot. If you plan to replace it anyway you dont have much to lose
You might check LKQ for a used or aftermarket part. My local facility has one available used (catalog #251-00229) for around $200.
If that doesn't pan out I can get you the OEM part numbers pertaining to just the upper pad (if they offer it that way without buying an entire assembly) and I also have access to a GM service department database that gives full service manuals for any model through 2009.
Just be prepared that replacing a dash is a LOT of work.. you'll have to take literally every part off the old one (radio, HVAC controls, IP cluster, trim parts, lower dash, etc.) and install it onto/into the new one. Not a job for the faint of heart.
When I bought it there was some very strong adhesive stuck to it. I tried to get it off but only made it worse. Now I have some permanent stains on it and I can't stand looking at it. The specific component I'm referring to is called the upper pad. I can't believe how expensive this piece is!
Yeah, I did that yesterday and it made it worse.
mcpp66...the best thing you can do is take it to a profesional uphoulstry shop and have them re-dye the dash. Unless yours is Sun damaged, you don't need a new one, just a pro re-dye
This is an alternative that I'll definitely look into. Thanks for the suggestions.
For the $200+ spent (new used dash) and time spent on removal and install on your part, I think you'll find thats the smart answer. Besides, if you buy a used dash it may have an adhesive spot on it
Another option is to install a hoola girl or a compass on the spot where your dash is suffering
$200 is really cheap compared to some of the other prices I've seen. I just wish I could see an illustration of what they're selling on their site. If you wouldn't mind getting me the OEM part number and the instructions I'd need to do it myself I'd greatly appreciate it. Although, from the sound of it that may be a job too big for a noob like me.
Where are you located?I would be glad to help you on the removal and Install. It's not hard, just time consuming!
Common sense and patience and a few tools will get the job done.
