Looking for a new Quick Detailer.
Sellncars
I wish there was a way to do a survey on here, I have been using Meguiars Final Inspection and have no issues, but would like to try something new, since my gallon is empty now. What does everyone else use?
Clearkote's Quickshine. Best I've found. Great for glass and chome too.
I have 2 favorites. The first is fk425, the second is Z6. Z6 cleans better.
Why not just go with what works...Megs FI. I would say if you really didn't like it, try something new because what have you got to lose. But if FI works with no issues, you run the risk of not being satisfied with another product.
It works great for me, just wanted to know what else is out there and if anything gives better cleaning properties along with the gloss effect.
OID my #1 QD out of many that I have tried. Leaves the surface so slick and had some decent cleaning ability.
Also I do mix S&W (75%) and S&G the other 25% if I need/want some cleaning power with some gloss enhancement left behind.
onr at qd dilution for cleaning then followed by oid. z6 followed by z8 would be my second choices.
Poorboys Spray and Wipe is my favorite. I have tried a bunch and always come back to PB S&W.
I have Spray and Gloss also. Doe's Spray and Gloss have a shine enhancer? I will have to try that 75 x 25. Thanks stang!
I like #521, Duragloss Marine / RV Detail Spray.
Removes dust, minor soil, oil film and water lines without removing the protective polish.
It's like QD on steroids.
try the new xmt QD I like it a lot, it cleans really well. also like, the PB QD+
If you want to stay with the Megs,try M135 it really did the job for me,still have half gallon,however since Ive switched up and using Fuzion now Ive been using the spray Souveran after washes and the cyrstal mist detailer,if needed which isnt very often anymore
Sonus Carnauba Spritz if QDing over a caranuaba finish. It contains Sonauba, the same Brazillian carnauba wax formula used in premium pure wax formulas or Sonus Acrylic Spritz, which contains Sonacrylicx, the same acrylic formula used in German high gloss sealants (ie: Klasse, Bove, Autoglym). Also, FK 425 and DG FCAS have given me great results for that deep gloss look. I don't think you can go wrong with any of the above mentioned. Nothing wrong with switching it up and trying new products. Just part of the fun.:cruisin:
Have you ever tried Meg's Last touch? Or how about #135. I like them both. The added benefit with the Last touch is that you can dilute it 1:1 for a great clay lube.
