looking for a specific spray sealant
szjalo
Hi all. A while ago I came across a product from this website, which is a spray sealant. the application is like: after washing the car, spray the sealant on the wet surface and rinse out with pressure washer. I couldn't quite remember the name/ manufacturer of this product. Do anyone have any recall on such a thing?
Otherwise if there are some new products working in similar fashion (easy to apply sealant) I sure would like to hear some recommendations.
thanks a ton
so how do you compare these products? mainly the Carpro Hydro2 and Gyeon Wet Coat?
pretty much settled down on carpro. one question tho, is carpro hydro2 (or hydro2 lite) compatible with the wax/sealant is the soap (meaning: can I used a wash&wax, followed by hydro2, or should I use a wax-free wash in prior?)
Using a wax fee soap is best!
Car Pro Reset leaves nothing behind.
thanks a ton
if you want a really great, easy to apply, cheap, and durable sealant try miguiars new fast finish.... you're welcome
As easy as UFF is to use, hydro2 is even easier. Nothing easier than spraying and rinsing off.
ya but then you're left with a type of coating right? can you use spray or regular wax sealant type stuff on top of what hydro leaves?
Correct. Hydro is an SiO2 sealant. Not as long lasting as a stand alone coating.
What is stopping someone from topping a coating with a wax or sealant? It seems like everyone wants to top a coating with a wax or sealant now a days.
CarPro offers reload which can be used on top if need be. Even ech2o mixed with reload as well if someone wants to stay with an SiO2 based combination.
You can top hydro all day long. Like any topping how long it actually lasts or changes the water shedding properties may vary
IMO the hydro is for ease of use and time saving while providing a competitive protective product on the car it's an alternative to having to go around and apply a wipe on wipe off sealant, wax, spray wax, wowa sealant etc.
But like I said you can top anything. No rules against it
