MrOneEyedBoh
Active member
- Mar 3, 2013
- 1,217
- 8
So I’m looking to give my truck a good clean for the first time since I bought it new in 2019. I’m looking to use something like IronX and GGs synthetic clay bar puck.
I’m guessing I should maybe wash it, then IronX and then run the clay bar over it? Does it make sense to also use IronX while going behind it with the clay bar? Or am I doing double work?
Also would using N914 as clay lube be a good idea? I found a gallon of it and didn’t know I had it, so if so - that’ll work great if it’s a good clay lube.
In the end, I’m going to polish the paint with GGs perfecting cream as the paint is good. I have other fine polishes but would most likely use the perfecting cream. With the truck being the Ford tricoat platinum white, it’s showing dirt and I’ll have to remove light swirling from claying.
