CaveRacing
- Jan 7, 2015
- 198
So get this - In this thread, we discussed a longer hose for the SunJoe SPX3000. I gave my opinion of a hose I recently bought, the Simpson 50' 5/16" (inside) diameter hose. It's a great hose. It doesn't kink, it isn't heavy, and it got great reviews. Some others here have even purchased it on my recommendation.
Well... when I first connected it to my Greenworks 1500psi PW, I noticed that the motor would run for just a second or two longer when the machine was powered on or when releasing the trigger. Also, when I pulled the trigger, it would take juuuust a second or so longer for the spray to flow. What was different? Before, whenever I released the trigger, the motor would immediately stop. When I pulled the trigger, it would immediately spray. Oh, the old hose was a 1/4" diameter 30' thermoplastic Briggs & Stratton branded hose. I don't much care for the thermoplastic. It is hard, gets brittle, yada yada yada. It was just like the cheap hose that comes with all of these machines, only longer. Hence, the new hose.
Ok, so my PW was having some funky issues anyway, so I didn't think much about these changes when I installed and used the new hose. Today, however, I decided to connect the old hose to see what would happen. Yep, it made it a difference. The reaction of the motor when I pull/release the trigger is much quicker AND the pressure was drastically improved! My little Greenworks machine is back to normal!
I know that the length of the hose can make a difference in pressure, but the difference in 30' and 50' is minimal when it comes to pressure loss. I mean, we're talking about a few PSI... nothing to really notice. The difference, however, is in the diameter of the hose. Apparently, going from 1/4" to 5/16" inside diameter DOES make significant difference in the performance of the pressure washer. BAH!!
I read some postings where people suggested upping the inside diameter if you're going to extend the length. So that's what I did with this Simpson hose. NOOOOO! And today, as I was reverting back to the old hose, it dawned on me that pressure increases as the diameter decreases. So what I effectively did with the new hose was decrease pressure by enlarging the inside diameter AND by lengthening the hose (albeit a negligible difference, I'm sure). :bash:
Since I like the material of the Simpson 5/16" hose, I found a 1/4" version at Lowes. At least, it looks and feels exactly the same, has the same "Morflex technology," but is branded BlueHawk. That's for Lowes. So I'll likely get this one. There aren't many 50' 1/4" QUALITY hoses to choose from, so this is probably the best bet.
So for anyone that is using a similar pressure washer (electric, cold water, 1500-2000psi), I'd suggest sticking with a 1/4" hose to maintain optimum performance.
Anyone need a virtually new Simpson 50' 5/16" diameter pressure washer hose?
Thanks for reading!
Thanks for reading!
