lot washing put vinger in tank water
cajunclean05
if i try vinger in tank water to help with stricking is it worth a try or does anyone have any other ideals
Yeah, mix some ONR in there, that will make your streaks easier to clean off. I guess you're just going to keep starting these threads until you get an answer you like?
What are you trying to acheive? Are you trying to not dry the cars? Or are you trying to make the drying easier? I believe there are some sheeting agents that could be used, similar to the sheeting agents that are used in dishwashers. As far as the availability of rinseless washes like ONR, sometimes RV stores carry those kinds of products, but I'm not sure that's really the solution to your problem...however, it should make the drying somewhat easier. You are pressure-washing with plain water, no soap or anything?
yes just plan water and im just trying to make dark cars look strikes less.
yes and they look good just some are a pan and the ass have to go over few times
iv herd of putting windex in there but idk or that dish washer stuff.
Putting ONR in there is going to be expensive, but maybe less expensive than extra drying time. Zep makes a number of drying agents that could be used for this purpose; look them up and contact their local rep.
Can you filter the water before you put it in the tank ?? Sounds like the minerals and contaminents in the water are the issue.
