Hi!
I am a new member and been doing research and found products I would like to use to detail my car. If anyone can please help answer my questions that would be great!
I want to detail my cars along with friends and family's cars with the best. All the colors I will be detailing are white, black, grey and red.
I have not brought any items yet as I am still researching on what to get and still looking for recommendations.
Tools that I have now are:
DIC-20 High Output Rolling System Spotless Rinse
Optima Steamer COMBY 3000
(A car body shop business was going out of business so I was able to get them at a decent price.)
Pre-Rinse/Wash Questions
I will be using/getting a Karcher power wash. Can anyone recommend me the best Karcher power washer if they tried all. I was planning to get the Karcher K 5.540 as it seem the one with most PSI and weight less. I am open to other brands to.
My questions is, do you all just pre-rinse with just water? Is it best to rinse with cold or hot water? Does it matter? Will pre-rinse with soap help? My plan was to pre-rinse with Iron X Snow Soap with a 1:8 Dilution. I was thinking that the Iron X Snow Soap pre rinse will help remove some of the iron and remove dirt etc before snow foam wash.
After pre-rinse with soap if you all think it's a good idea, should I rinse it off with water or go straight to foaming the car? What soap is the best for foam and cleaning? I was recommended Lusso Auto bathe and Pinnacle Shampoo. Which other ones do you guys recommend. For the guys that used both which one do you guys prefer or if you used all sorts of and settle on another brand what is it? Any reasons why?
After the snow foam should I rinse it off? Or should I go straight to washing it with the two bucket method and then rinse after?
Drying Questions
Since I will be using the DIC-20 for all my rinse, is it best to use a leaf blower or get a Metro Master Blaster to get water off the car? If I use either, I will use a MF cloth to go over teh car to make sure I get all water off. Anyone recommend a MF cloth for just drying?
Iron X
After the car is dried off, I want to spray on Iron X. I haven't used Iron X before, so please correct me if I'm wrong. Will I just spray on Iron X to the car and let it sit until it turns purple/red and then rinse? Or will I need to spray and go over it with a MF Cloth?
Clay
After I Iron X or if I skip that step; I will be claying. I was recommended Clay Magic clay as I was was told it owns the patent and everyone gets their clay from them? Will any clay do or is there really a difference in clay from other company? If so which is the best one you used? Which lubricant detail spray do you use with your clay?
Has anyone worked with Nano Skin Scrubber? If you have would you prefer this over clay? Does it really save more time and clean better then clay?
One Step Polish
After my clay if the paint is not in bad condition I was planing to do a one step polish with a Flex 3401. I heard many great things about the Flex 3401. I had people suggest me the PC7424 but I think I will go with the Flex3401 unless someone else can convince me why I should go with other ones.
I plan to use Menzerna Power Finish as my one step polish and top it off with Menzerna Powerlock. Any other one step polish people would suggest over the Power Finish? Any other Sealant people would suggest over powerlock?
Wax
I wanted to apply wax to the car after the powerlock has been cure which I was told about 12 hours? If that is wrong can anyone give me a better time to let it cure? Will any wax work on top of the powerlock? Only wax that I was recommended for the best is Fuzion. Will Fuzion work on top of the powerlock with no issue? Should I skip wax and just apply another coat of powerlock?
Compound/Polish
My BMW X3 has lots of scratches that I know I will need to compound it out. If needed I will wet sand with grit 1500 paper. Here was what I planned, if anyone can suggest something else or comment what I will be using that would be great.
Compound - M105 with D300 (2 dots each on the pad)
What pad is best for M105/D300 combo? Will a 5.5 surbuf pad do? Any other compound recommendation?
Polish - Menzerna Power Finish
Which pad will be best? Any other Polish recommendation?
Finishing Polish - Menzerna SF4500 (85rd)
Which pad will be best? Any other Finishing Polish recommendation?
Sealant - Menzerna Powerlock
Which pad will be best? Any other sealant recommendation?
Again colors I will mostly detail are white, grey, black and red.
After the car has been compounded and polish, do you guys wash the car again or just spray the car over with detail spray? Which detail spray has worked best for you? Which MF cloth do you use with your detail spray?
Interior
Leather cleaner/conditioner
Which interior leather cleaner/conditioner do you guys use? I heard many great things about 1Z. Anyone suggestion anything else?
Carpet shampoo
Anyone suggestion any shampoo for carpets? I will be using the COMBY to vac and steam carpets and it has the option to steam with shampoo. Which shampoo have you used and worked best with carpets?
Dash
I will be using 1Z cockpit. Anyone suggest anything else?
Thanks! Any input would be great!
Drying Questions
Iron X
Clay
One Step Polish
Wax
Compound/Polish
Interior
Carpet shampoo
Dash
