I work with a rotary and foam pads, stay away from wool being a weekend warrior. I have tried M105 a few times, didn't like it one bit and it could be that it is designed to be used with wool pads. I made the switch to DAT compounds from Scholl and Menzerna and they have been working well for me. I want to try the Meguiar's compounds again and more importantly cut my cost as the German compounds are rather expensive. Should I try Ultimate compound or M101 or M100 on the rotary?
Also, does Meguiar's have an entire range of polishes and compounds like Scholl/Menzerna with varying cutting abilities? M105 / M205 combo seems too harsh when at times all I need is grit 2500 cutting compound at at times only P3000. Scholl does this well starting with S0,S2,S3,S17,S20,S30 and finally S40.
