I've been using m205 for quite a while on all different paints. My personal vehicle is a 2013 Jetta in a dark metallic blue.
I have about 95% correction as of now. There's a few RIDS and chips but I can deal with that. It's when I was cleaning up from this brutal northeast winter, all of the water spots and such that I used 205 on a flat LC white pad.
After doing 5 passes up then down, up and down again over a 2x2 area, I was ready to wipe off. I only used about 4 pea sized drops after the pad was completely primed. Anyways, when I went to wipe off, it came off fine but when I checked in the sun, I could see these striations going the way of my towel, side to side.
I'm thinking a few things.
One being my towels are just not as clean as I thought they were although a visual inspection tells me they're pretty clean. I clean them properly with all necessary measures.
Secondly, though 205 is non diminishing, could I need to work the product longer?
Finally, I did use Menz inspection to remove oils and residues. I felt this made everything granny and could lead to marring. If that is the case, do I remove oils by just re washing with a citrus wash instead?
I'm puzzled and frustrated.
