Has anyone had great success with using M205 along with megs finishing microfiber disc? How well do it Finish out?
If you need a one step correction then it works fine depending on the hardness of the paint. On softer paints it can leave hazing behind due to the abrasives in the product and the fibers on the pad acting as an abrasive. M205 still tends to finishes out better on foam than on microfiber.
The D302 polish contains no abrasives so it will tend to finish out better than M205.
What are you trying to accomplish?
I do have D300 D301 and also D302 Only reason I ask is because I love microfiber pads and there cutting ability and just wanna see how many different combos I could use with them
I love it!
Finishes beautifully. I used it on a white Land Rover Suv. It cut ridiculously fast, and left a great finish. My typical "one step" is M205, Ultimate Polish, or Rupes Keramik on Buff and Shine, Meguiar's or Rupes microfiber finishing pads.
I havent used mf finishing pads much, just Rupes ones once. Is there much difference between bns, rupes and megs mf finishing in terms of cutting and finishing?
