Can M205 remove light swirls when used with proper pad? After M205 can I go straight to M26 for the wax? I was thinking of using either a LC orange or yellow pad for the M205. Suggestions on the pad for the wax?
Basically I would like to start with M205 after claying to remove the swirls and then go to the wax if I dont need to use anything else. I understand that after M105 I would want to follow up with M205 to remove some of the compound marks but with the M205 being more of a polish with a light cut I would think I could directly go to wax after. I think that I have used M7 between M205 and M26 but is this really needed? Does the M205 leave the surface ready for the wax or sealant?
