Machine Dampsanding Question
MustangFstbk
I am considering getting an electric DA to use for dampsanding my freshly painted Mustang. I have always wetsanded by hand and this will be my first go at machine sanding. I am trying to decide whether to go with the griot's garage 6" or 3". The 3" seems to be more versatile because it is smaller but I am worried that sanding large panels with 1500 and 3000 using a 3" pad might risk sanding a rut into the finish. Is the 3" model meant more more for where a 6" is to big to fit? If so, would it be better to hand sand up to 1500 then machine sand with 3000 on the 3". Or would it be better to get the 6" version and just hand sand the areas the 6" can't reach? I wouldn't use it often enough to justify getting both. Thanks for the advice!
First, since this is your first post to the forum...
Welcome to AutogeekOnline! :welcome:
As long you use some type of controlled, repeatable pattern and focus on the job at hand you won't put ruts into a large flat panel.
Yes and also for sanding next to raised body lines and edges. The 3" polisher with a 3" interface and sanding disc is VERY easy to control. That's what all the people that go through my classes like about it, in fact in all most all the pictures taken of people new to wetsanding almost all of them show guys using the 3" instead of the 6". It's just that easy.
Very good question.
I guess if I had to pick just one electric polisher to get to machine sand an entire car, I would tend to go for the full size DA polisher and a 6" sanding system. This is especially true for a large car with a lot of large flat panels.
If time is not an issue and there are a lot of thin panels, tight areas then you could sand the entire thing down with a 3" Griot's polisher.
It will take longer for large sections because the footprint is so small but inch by inch, any thing's a cinch.
You could also hand sand to start with to knock down all the orange peel and then just use the 3" polisher to refine your sanding marks.
Look at all the pictures in these two threads to get a visual of what it looks like to dampsand using a 3" polisher.
Griot's 3" Mini Polisher works great as a 3" Dampsander
Dampsanding with 3" Griot's Garage Mini Polisher
I have an advanced class this weekend so next week you'll see even more pictures of guys using the 3" sander to sand down fresh paint...
Advanced Paint Polishing - Production Detailing & Show Car Detailing
My next advanced paint polishing class that focus on maximizing profitability for production detailing and wetsanding, cutting and buffing for a show car finish will be February 23rd and 24th. This class is limited to 8 people. For the advanced classes I've already confirmed the below cars.
1970 Oldsmobile Cutlass - Fresh PPG Basecoat/Clearcoat Paint System - Wetsand, Cut and Buff
Register for the February 23rd & 24th Advanced Paint Polishing Class
:xyxthumbs:​
Thank you for your quick response! I am sold on the 3". Ease of use and flexibility is exactly what I am looking for. One more question I just thought of. After wetsanding, I am guessing the 3" model could be used to compound and polish smaller pieces that you wouldn't want to hit with a large rotary buffer? Even if it was slower to buff out with the 3", it seems it would be much better than going at it by hand. If you can compound and polish with the 3", could you recommend compounding and polishing pads? I found some for the 3M 3-step process but I have used Meguiar's M105/205 and wasn't planning on switching to the 3M setup since I have plenty of left over compound and polish, and like the Meguiar's product. Or would you recommend going with the 3 step process when using a DA over a rotary buffer? It's a black car so every scratch and swirl will show... Thanks again for the advice! This forum and your how to articles are such a great resource!
