Machine Wetsanding Options?
Chase_910
I have a boat restoration project to complete over the winter. The job is going to require extensive gel coat wet sanding. To date I have always wet sanded by hand but I'm exploring the possibility of wet sanding by machine to speed up the process.
Does anyone use a buffer/sander to wet sand gel coat? If so can you describe the equipment used (buffer, BP, Pads, lube) and your technique.
Thanks for your feed back.
