Dave Medvic
- Oct 23, 2012
- 132
My vista print signs left white marks on my truck, tried buffing it out but no luck yesterday. Any of you run into this before? I can try a different compound tonight or wet sanding, didn't expect this.
Thanks Dave,I'm assuming the white marks are from dirt getting between the magnet and the paint and abrading away at the clearcoat. I've fixed a lot of vehicles with this problem. Depends on how severe the problem is on how aggressive you need to go to buff it out. I've had many that needed to be buffed out with rotary and wool pad.
Also, things (liquids) that can degrade paints such as hard water, detergents and other types of fallout can get behind the magnet and dwell on the paint leaving a chemical etching.
