Using Meguiars hyper dressing for shine on my tires. It is turning my wheels a brownish color. Which doesn't come off with light brushing and simple green.
Anyone experience this.
I ordered some Carpro Multi X for tires. Reset wasn't removing enough of the brown.
Have you tried TW Hyper Foam Tire cleaner yet? You really need to. It's that good. I washed my sons Cruze yesterday. Its been 30 days since I washed it last. Parks outside 24-7 and he drives it daily. 2 applications of the cleaner and the tire is coating ready.
I've tried many tire cleaners. And I just don't see the need to pay MORE money for cleaners that do relatively the same thing that TW can do cheaper and faster.
Give 303 T&R a try. My favorite for tires.
The brown is called Blooming and isn't from Hyperdressing. I've been using it for years with no issues.
Black Magic Bleche-Wite Tire Cleaner is cheap and effective at removing the brown blooming that you're seeing. If bad, it may take 1-2 scrubbing sessions.
As others noted, stop using Simple Green. The blooming is from the tires releasing antiozonant which is part of the manufacturing process. It actually prevents dry-rot and tire-cracking caused by ozone, sunlight, etc. that tires are exposed to. Simple Green likely causing it to be pulled out in droves.
I liked 303 when I used it. Foamed really good, cleaned pretty good and its color changing formula for tires is something you don't see for any other tire cleaner. Not sure its useful but cool to look at I guess, LOL!
Only problem is the price. $25 for a bottle is just way too steep (even if it is 32 oz). At half the cost, a 23 oz bottle of TW Hyper Foam Tire Cleaner does as good a job, if not better. AND the best thing is Hyper Foam comes in gallon sizes (303 does not) and it costs only 10 bucks more than a bottle of 303! Insane value for a superb tire cleaner. Oh and did I mention you can dilute Hyper Foam from the gallon size? You can cut 1:1 and essentially get TWO GALLONS of tire cleaner for $35. <mind blown>
